How to catch the below Drops using IOS XR ,Which Debug/Show Command let me catch the result of the Below config
Ibrahim Jamil
Level 6
Level 6
Hello Guys How to catch the below Drops using IOS XR ,Which Debug/Show Command let me catch the result of the Below config !***Drops common CSG community*** if community matches-any (10:10) then route-policy R2-BGP_Egress_Transport_Filter !***Passes FAN Loopbacks*** if community matches-any (20:20) then pass else !***Passes Communities in R2: 10:201, 10:202, etc.*** if community matches-any (10:2*) then pass !***Drops common CSG community*** if community matches-any (10:10) then drop else pass endif
Giuseppe Larosa
Hello Ibrahim,
it would be kind of you, if you write your posts with configuration sections in a more readable format.
it will increase the probability to get better help.
Respectfully this is only my personal opinion.
The following slides by Cisco expert Vinit Jain can be helpful
https://community.cisco.com/t5/networking-documents/webcast-slides-border-gateway-protocol-bgp-fundamentals-and/ta-p/3155886
In IOS XR a route-policy is applied to an attach point for example a BGP neighbor session is likely your case.
The show commands are likely
show bgp neighbor x.x.x.x advertised-routes
show bgp neighbor x.x.x.x received-routes
with the second command likely showing you all the received routes from neighbor before an inbound route-policy can act on them.
Edit:
if the route-policy is applied inbound you should see differences between
and
show bgp | inc x.x.x.x
Actually only show bgp <prefix> can show you all the BGP attributes including the BGP standard communities that are the selection criteria in your route-policy config example.
Again using a debug command is not recommended for the added load on devices.
Edit2:
to see all the details of a route policy with expansion of all sets objects you can use
show rpl policy-route <name> detail
see
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-4/routing/configuration/guide/b-routing-cg-asr9000-64x/b-routing-cg-asr9000-64x_chapter_01011.html?dtid=osscdc000283#task_1079601
Best Regards
Giuseppe
