How to check EtherChannel LB on ASR1K.
mhiyoshi
Level 3
Level 3
Dear all,
I think Catalyst9K can check the etherchannel LB Dest Port with show command however ASR1K can also configure routed etherchannel but how to check with show command?
[Cisco ASR 1000 Series Aggregation Services Routers Software Configuration Guide, Cisco IOS XE Gibraltar 16.12.x]
 https://www.cisco.com/c/en/us/td/docs/routers/asr1000/configuration/guide/chassis/xe-16-12/asr1000-software-config-guide-16-12/evc-port-chann-asr.html
Example on Catalyst9K
show platform software fed switch 1 etherchannel 1 load-balance ip 1.1.1.1 2.2.2.2
Dest Port: : GigabitEthernet1/0/1
Best Regards,
Masanobu Hiyoshi
IOS XE is for Cat9k and ASR 1K but some command function in Cat9k not functional in ASR1k
