L2/L3 IOS Image NAT is not working in EVE-NG Environment
Translator
Community Manager
Community Manager
Hi, all. Please help me on this.
I have been setting up the L2/L3 configuration with the i86bi_linux_l2-adventerprisek9-ms.SSA.high_iron_20190423.bin image in the EVE-NG virtual environment.
I'd like to use NAT on the switch in the image, but there is a problem that it does not work properly.
To be precise, when I tried to communicate from the network connected by nat inside interface to the network of nat outside, NAT is not working. However, if I try to communicate by specifying the source as inside on the device where I set NAT, it works okay.
You can see the pings that occurred at 192.168.141.41 do not travel on the NAT, so the communication is not performed, but the communication is normal at outside.
If I specify the source when debug is enabled, I can confirm that NAT is working normally.
I'd like to know if it's the problem with the image or if I misunderstood and set it wrong. Please kindly check below.
R1#show run
Building configuration...
Current configuration : 1552 bytes
! Last configuration change at 01:22:59 UTC Tue Dec 20 2022
version 15.2
service compress-config
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
ip cef
no ipv6 cef
spanning-tree mode pvst
interface Ethernet0/0
no switchport
ip address 192.168.141.1 255.255.255.0
ip nat inside
ip ospf 1 area 0
interface Ethernet0/1
no switchport
ip address 123.11.22.2 255.255.255.252
ip nat outside
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet1/0
interface Ethernet1/1
interface Ethernet1/2
interface Ethernet1/3
interface Ethernet2/0
interface Ethernet2/1
interface Ethernet2/2
interface Ethernet2/3
router ospf 1
default-information originate always
router bgp 31112
bgp log-neighbor-changes
neighbor 123.11.22.1 remote-as 65100
ip nat inside source route-map ISP-65100 interface Ethernet0/1 overload
ip forward-protocol nd
ip http server
ip http secure-server
ip route 0.0.0.0 0.0.0.0 123.11.22.1
ip ssh server algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip ssh client algorithm encryption aes128-ctr aes192-ctr aes256-ctr
ip access-list extended NAT-R1
permit ip 192.168.0.0 0.0.255.255 any
route-map ISP-65100 permit 10
match ip address NAT-R1
match interface Ethernet0/1
control-plane
line con 0
logging synchronous
line aux 0
line vty 0 4
end
balaji.bandi
what is the image version and file name you using on this lab ? some image have some issues.
Try below 2 solution and see if  that works ?
Option 1 :
no ip nat inside source route-map ISP-65100 interface Ethernet0/1 overload
ip nat inside source list 100 interface Ethernet0/1 overload
ip access-list 100 Permit 192.168.0.0 0.0.255.255 any
Option2 :
try remove ip cef and test it
no ip cef
BB
balaji.bandi
Option 1 :
Option2 :
no ip cef
BB
not all SW support NAT in real network,
so I prefer use router in Stick instead of using SW and config NAT in router.
this better
