ASR1K - L2TP tunnels not working and no debug logs
therebel22
please we need help :
we have made migration from CISCO 2821 to ASR1002-X.
Cisco router is used as LNS for our ADSL links, using L2TP protocol. On 2821, everything worked fine. Migrating with same config on ASR1002-X, everything worked except L2P sessions.
We wanted to debug but no debug is displayed about L2TP or PPP in console with commands :
- debug aaa authentication
- debug aaa authorization
- debug radius
- debus vpdn l2x-events
- debus vpdn l2x-errors
- debus vpdn l2x-packet
- debug ppp negotiation
- debug ppp authentication
We don't understand why no debug log ??? Is it a bug in IOS XE ?
show vpdn session all and show vpdn tunnel all gave "%No active L2TP tunnels"
Thanks a lot for help !!
Here our configuration :
sh ver
Cisco IOS Software, IOS-XE Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 1
5.2(4)S1, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Sat 06-Oct-12 13:03 by mcpre
IOS XE Version: 03.07.01.S
License Level: ipbase
License Type: Permanent
Next reload license Level: ipbase
cisco ASR1002-X (2RU-X) processor with 1156257K/6147K bytes of memory.
Processor board ID SSI16450ENF
6 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
6684671K bytes of eUSB flash at bootflash:.
Here our LNS/L2TP configuration :
aaa new-model
aaa group server radius Telco-RADIUS
server-private x.x.x.x auth-port 1812 acct-port 1813 key secret
server-private y.y.y.y auth-port 1812 acct-port 1813 key secret
aaa authentication ppp Telco-DSL-AAA group Telco-RADIUS
aaa authorization network Telco-DSL-AAA group Telco-RADIUS
aaa accounting network Telco-DSL-AAA
action-type start-stop
group Telco-RADIUS
aaa session-id common
vpdn enable
vpdn history failure table-size 50
vpdn search-order multihop-hostname domain dnis
vpdn-group ADSL
accept-dialin
  protocol l2tp
  virtual-template 2
terminate-from hostname bas1
local name LNS1
lcp renegotiation always
no l2tp tunnel authentication
ip mtu adjust
interface Virtual-Template1 type serial
description VT1
mtu 1460
ip unnumbered Loopback0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1420
ip policy route-map INTERNET_VT1
timeout absolute 1800 0
no peer default ip address
ppp authentication chap pap Telco-DSL-AAA
ppp authorization Telco-DSL-AAA
ppp accounting Telco-DSL-AAA
ppp ipcp address required
ppp ipcp address accept
26 Replies 26
Subeh Sharma
I can see you've configured Virtual-template 1 but under vpdn-group, virtual-template 2 is called:
vpdn-group ADSL
accept-dialin
  protocol l2tp
  virtual-template 2
Do you have a virtual-template 2 configured?
Also, can you run 'debug vpdn l2x-event' on the LAC and see if LAC is initiating a L2TP tunnel to the LNS?
Subeh
Sorry,
it's a typo error. Yes we have a virtual-template 2 :
interface Virtual-Template2 type serial
description VT2
mtu 1460
ip unnumbered Loopback1
ip nat inside
ip policy route-map INTERNET_VT2
Subeh
When i launch that command :
And all others command, i hav no debug log on console about vpdn or ppp. I don't understand why. debug log worked well on 2821..
And Loopback interfaces :
interface Loopback0
ip address a.b.c.d 255.255.255.255
interface Loopback1
ip address e.f.g.h 255.255.255.255
interface Loopback2
ip address i.j.k.l 255.255.255.255
The debug i suggested was to be run on the LAC and not on LNS which you're ASR is configured as.
Subeh
The LAC is owned by another provider, we can't acces it... Do you know an issue on ASR1K whereno debug log is produced about aaa or vpnd ?
No, there is no such bug that i know of. Where are you checking the logs i.e. in the logging buffer(show log) or on router's console or in SYSLOG? Also what have you configured for logging on the ASR?
Subeh
thanks  for reply.
Router console with serial link or syslog on another server. We only see log about enter configure terminal or command typed but absolutly no log about aaa or vpdn whereas debug log are enabled
So, you've configured for SYSLOG? Can you paste the logging commands you've on ASR, here?
Logs will be shown when ASR receives a L2TP tunnel request from the LAC. Are you able to ping the LAC's IP?
Subeh
I'm looking for logs on our syslog server. I'll give you soon. Thanks.
Sorry for delay. Here the log that was repeated when config was modified :
May 19 09:33:40 X.Y.Z.1 510: May 19 08:33:42.502: VT[Vt1]:Subinterfaces may be created using this config
May 19 09:33:40 X.Y.Z.1 511: May 19 08:33:42.502: VT[Vt1]:Generated an interface command list
May 19 09:33:40 X.Y.Z.1 512: May 19 08:33:42.502: VT[Vt1]:Generated a subinterface command list
May 19 09:33:40 X.Y.Z.1 513: May 19 08:33:42.502: VT[Vt1]:Generated a ppp_only interface command list
May 19 09:33:40 X.Y.Z.1 514: May 19 08:33:42.502: VT[Vt1]:Generated a ppp_only subinterface command list
May 19 09:33:40 X.Y.Z.1 515: May 19 08:33:42.502: VT:Clean up dirty vaccess queue, size 1
May 19 09:33:40 X.Y.Z.1 516: May 19 08:33:42.503: RADIUS: Removing all radius source-int. pointing to Virtual-Access1.1
May 19 09:33:43 X.Y.Z.1 517: May 19 08:33:44.884: AAA/AUTHOR: auth_need : user= 'root' ruser= 'LNS1'rem_addr= 'X.Y.Z.13' priv= 0 list= '' AUTHOR-TYPE= 'commands'
May 19 09:34:32 X.Y.Z.1 518: May 19 08:34:35.190: AAA/AUTHOR: auth_need : user= 'root' ruser= 'LNS1'rem_addr= 'X.Y.Z.13' priv= 0 list= '' AUTHOR-TYPE= 'commands'
May 19 09:34:33 X.Y.Z.1 519: May 19 08:34:35.190: %SYS-5-CONFIG_I: Configured from console by root on vty0 (X.Y.Z.13)
Any idea ?
What do you think of configuration ? Does it seems good for you ?
Thanks.
Sorry, was busy in the day so didn't get a time to check this. So, i see alot of mesages now in your last output. Anything changed? I'd say your configuration is complete and contains all the commands required. Since you're able to see debugs now, can you check show l2tp tunnel all?
Subeh
