how to check over utilazation on cisco router
kumar86rakesh
We have 4 MBPS Point to Point Link . We are facing link slow issue in our branch. I have also complained to the service provider but they are saying  that your link might be over utilized thats why its working slow , but i don't know how to check it on router .I have the router access .
So Please tell me how can I check over utilization.
Here is show int result of my router
Router#sho int
FastEthernet0/0 is up, line protocol is up
  Hardware is Gt96k FE, address is 0025.846c.2504 (bia 0025.846c.2504)
  Internet address is 192.168.xxx.XXX
  MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
     reliability 255/255, txload 10/255, rxload 1/255
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, 100BaseTX/FX
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 141000 bits/sec, 239 packets/sec
  5 minute output rate 4010000 bits/sec, 349 packets/sec
     965392973 packets input, 3528880026 bytes
     Received 476300 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog
     1185739001 packets output, 365695133 bytes, 0 underruns
     0 output errors, 0 collisions, 2 interface resets
     0 lost carrier, 0 no carrier
FastEthernet0/1 is up, line protocol is up
  Hardware is Gt96k FE, address is 0025.846c.2505 (bia 0025.846c.2505)
     reliability 255/255, txload 1/255, rxload 10/255
  Last input 00:00:08, output 00:00:00, output hang never
  Input queue: 0/75/18/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 4015000 bits/sec, 348 packets/sec
  5 minute output rate 139000 bits/sec, 242 packets/sec
     1183440357 packets input, 707446510 bytes
     Received 2081 broadcasts, 0 runts, 0 giants, 18 throttles
     0 watchdog
     969347742 packets output, 1487102503 bytes, 0 underruns
     0 output errors, 0 collisions, 5 interface resets
Serial0/0/0 is administratively down, line protocol is down
  Hardware is GT96K Serial
  MTU 1500 bytes, BW 1544 Kbit/sec, DLY 20000 usec,
  Encapsulation HDLC, loopback not set
  CRC checking enabled
  Last input never, output never, output hang never
  Queueing strategy: weighted fair
  Output queue: 0/1000/64/0 (size/max total/threshold/drops)
     Conversations  0/0/256 (active/max active/max total)
     Reserved Conversations 0/0 (allocated/max allocated)
     Available Bandwidth 1158 kilobits/sec
     0 packets input, 0 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     0 packets output, 0 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
     0 carrier transitions
     DCD=down  DSR=down  DTR=down  RTS=down  CTS=down
Serial0/0/1 is administratively down, line protocol is down
johnlloyd_13
Level 9
Level 9
hi,
is your ISP link an ethernet hand off?
look under FE0/0 interface:
5 minute output rate 4010000 bits/sec, 349 packets/sec   <<< 4.01 Mbps UPLOAD
rosaho
Level 3
Level 3
This discussion has been reposted from Cisco User Groups to the WAN, Routing and Switching community.
johnlloyd_13
Level 9
Level 9
hi,
