How to check received power on OC3 SFP?
netone.cisco
Hi all,
we have a 7206vxr router with pa-pos-2oc3 and SFP-OC3-IR1-C. Our provider wants us to check transmitted and received power on the SFP.
I already looked around and know theres no way to check or adjust transmit power and saw its -15 to -8dbm on the datasheet.
Is there a way to check received power??
IOS version
7200 Software (C7200P-ADVENTERPRISEK9-M), Version 12.4(24)T3
vmiller
Level 7
Level 7
In your case, you will need a handheld meter. you will need to disconnect the fiber from the router and connect it to the meter.
take a look at fluke products....
vmiller
Level 7
Level 7
vmiller
Level 7
Level 7
VMiller thanks very much. this is an option but we were hoping there was an option that would allow us to continue using the link without having to schedule a maintenance windows.
Mario Pinho
sorry about the double post. I'd suggest (if you aren't doing this already) have a
meter and cleaning kit. every time you pop the jumpers off, clean them before you put them back on
it a good safe practice.
