DHCP on WAN interface 6500
paarlberg
I have a 6509 with SUP2 w/msfc2 at home, I am currently have dsl for internet with static IP addresses. Due to AT&T not wanting to support faster speeds in my area, I have to look at another option. All of these will be dynamic IP addresses, cable, uverse, etc.
I need to be able to enable dhcp on the wan interface so I can connect directly into one of the gig ports (either on SUP2 or 6316) or on a 10/100 port on a 6348.
I have the following image installed s222-adventerprisek9_wan-mz.122-18.SXF13.bin, according to Cisco's feature tool, it is supported.
I have tried "ip address dhcp" on the interfaces but they will only accept "ip address x.x.x.x", I looked at "ip dhcp" as well and only get the option for "relay".
Any suggestions? I would hate to have to put something else in the mix to handle the dhcp portion. I may be keeping the adsl for my mail server traffic and backup in case of an outage on the new provider. So I need to be able to track if a link is up.
Nikita Singh
Can you please send me ,
show run int
show int
I'm assuming that it is a layer 3 interface.
I can use any of the available interfaces on the switch.
I have the following modules installed
SUP2-2GE (2 gbic slots)
6348 (48x 10/100)
6316-GE (16x GE copper)
Yes it is running Native IOS only.
Mark Rigby
Have you tried issuing the command "no switchport" on the interface then enabling DHCP using "ip address dhcp"?
SWITCH(config-if)#no switchport
SWITCH(config-if)#ip address dhcp
Yes I have. It is not a recognized command.
I only have the option to set an IP x.x.x.x or dhcp relay. It appears that it may be a bug in 12.2-18.SXF13 as someone reported on dslreports forum that it works in SXF15.
I have issues getting SXF15 or newer to boot from the flash card.
