How to clear dsl counters?
lamin.sonko
Hi I'm troubleshooting an atm/dsl interface on a 877 router. We have some problem whit CRC errors and Header errors. My problem is that I want to clear the counters(errors when "show dsl int atm 0"),
I have tried:
clear atm
clear int atm 0
clear counters atm
But nothing seems to work, is there another way to clear these counters.
7 Replies 7
mohammedmahmoud
Level 11
Level 11
"clear counters atm 0" should do it.
If there is no problem in clearing all the counters on the router do "clear counters" and it should clear all your counters.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
tried clear counter atm 0.
this clears only atm interface. I want to clear the information shown when command "sh dsl int atm 0". This is high-level DSL port information.
/ Lamin
As i told you before, if there is no problem in clearing all the counters on the router do "clear counters" and it should clear all your counters.
Mohammed Mahmoud.
Any good advise on the original question?
"clear counters" doesn't clear the stats when doing the command: show dsl int atm 0 which is what was originally asked. Clear counters only clears interface stats
serge123
Only a reload will clear these counters.
Thanks for the helpful reply!
CRC Errors: NA 5249887 NA 3695
r01c43#clear controll vds 0/2/0
r01c43#show controll vdsL 0/2/0
CRC Errors: NA 0 NA 0
Clear controller - clear controller counters
Clear interface - resets interface
Clear counters - clear interface counters
