How to config edge network to send traffic to two ISP connections that are different speeds
deyster94
Level 5
Level 5
I have a client that currently has two 100 meg connections to the Internet from the same provider.  They are going to upgrade one to a 500 meg connection soon and it will be from a different provider.  Their edge routers are connected to the provider using BGP and to their Palo Alto FW's using OSPF.  What is going to be the best way for them utilize the 500 meg connection over the 100 meg connection?
TIA for ideas.
Dan
paolo bevilacqua
You will need to set some routing metrics. Details depend on the exact situation/topoloy and are better worked out with a qualified/ciertified network engineer.
PfR with an inline master controller....
Innovative and very efficient especially with the IOS 15.X series.
A little bit of study required :(
Hope to help
Alessio
