How to config router c1100 series
WanisaCh
I don't know how to config router c1100 series.
ip address pc1: 192.168.10.10
ip address pc2 : 192.168.10.20
ip address server : 171.168.10.10
Client external come into use remote server
3 Accepted Solutions
some of the interfaces in the Router have Lan switching ports. ( to guide correctly post - show run and show version output)
give you some idea :
config interface in access vlan and create a SVI Interface and allocated IP address example :
config t
vlan 10
interface gi 0/10
switchport access vlan 10
no shutdown
interface vlan 10
IP address x.x.x.1 255.255.255.X
no shutdown
where PC connecting to gig 0/1/1 (example)
interface gig 0/1/1
no shutdown
PC IP address
x.x.x.2 255.255.255.X
gateway x.x.x.1 (PC should able to ping router)
BB
Hope we are discussing here C1111 Router, the image show you booting with Cat 9K image this is not correct.
diagram i need switch redundance and to internet. I can't ping cross network    - Not sure if I understand this question correctly, if you have only 1 Router and 1 ISP link and 1 Switch you do not need HSRP here - until we understand the requirement correctly and what network you have.
 question
router ISR C1111-4p switch port
can do config HSRP right?  - read the above answer.
BB
as per the information you do not need HSRP here, since you have 1 device and 2 access switches. and 1 ISP Link I do not see a use case here for HSRP.
BB
11 Replies 11
balaji.bandi
start with the below document configuration guide, and make a basic config, if you are stuck anywhere
post-show run
here to community help.
https://www.cisco.com/c/en/us/td/docs/routers/ios/config/17-x/lan-wan/b-lan-wan/preface-reuse-routing.html
BB
I don't assign ip address at interface
gig 0/1/0 , 0/1/1,0/1/2,0/1/3
CLI not have command "ip address"
config t
vlan 10
interface gi 0/10
no shutdown
interface vlan 10
no shutdown
interface gig 0/1/1
no shutdown
PC IP address
BB
Thank you
but i use
command factory
reset all alert warning below picture.
i can't download software image
hi balaji.bandi
I question router
 ISR C1111-4p
switch port can do config HSRP right?
 question
BB
Diagram 1 Router(C1111-4p),1 ISP link, 2 Switch(C9200L)
BB
Thank you for direction.
if you are happy with the suggestion, and no further assistance is required, can we mark it as resolved, so this will be helpful for our community members?
BB
