How to config static when multiple paths
goyourmin
hello!
There is a box-type topology as follows.
I want to configure the
default static route
in the direction of ISP.
(L3-Switch-5 -> L3-Switch-3 -> L3-Switch-1 -> ISP)
I envisioned the
in the upstream, and the
static route
in the interlink and downsteam.
With this idea, I applied it to EVE-NG. As a result of observation, I saw that a loop occurs through the interlink.
When
pinging L3-Switch-5 -> L3-Switch-1
Loop occurred between the
L3-switch-3 and L3-switch-4
interlinks.
I think I'm wrong somewhere, but I'm not sure.
Also, if these Link down, do users need to change the settings?
This is a topology that takes into account the occurrence of failures.
* there is no alternative to this static configuration in the environment. (Dynamic protocol not supported)
- L3-switch-1
ip route 0.0.0.0 0.0.0.0 eth0/3 (ISP main route)
ip route 10.10.10.0 255.255.255.0 eth0/1
ip route 10.10.10.0 255.255.255.0 eth0/0 100
ip route 10.2.2.2 255.255.255.255 eth0/0 100
ip route 10.3.3.3 255.255.255.255 eth0/0 100
ip route 10.4.4.4 255.255.255.255 eth0/0 100
ip route 10.5.5.5 255.255.255.255 eth0/0 100
ip route 10.6.6.6 255.255.255.255 eth0/0 100
ip route 172.16.2.0 255.255.255.252 eth0/0 100
ip route 172.16.3.0 255.255.255.252 eth0/0 100
ip route 172.16.4.0 255.255.255.252 eth0/0 100
ip route 172.16.5.0 255.255.255.252 eth0/0 100
router bgp 2
bgp router-id 10.1.1.1
network 100.100.100.0 mask 255.255.255.252
neighbor 100.100.100.1 remote-as 1
redistribute static
- L3-switch-2
ip route 0.0.0.0 0.0.0.0 eth0/3 100 (ISP backup route)
ip route 172.16.1.0 255.255.255.252 eth0/0 100
router bgp 2
network 100.100.100.4 mask 255.255.255.252
neighbor 100.100.100.5 remote-as 1
redistribute static
- L3-switch-3
ip route 0.0.0.0 0.0.0.0 eth0/1
ip route 10.10.10.0 255.255.255.0 eth0/2
ip route 10.1.1.1 255.255.255.255 eth0/0 100
ip route 172.16.0.0 255.255.255.252 eth0/0 100
- L3-switch-4
- L3-switch-5,6
ip route 0.0.0.0 0.0.0.0 eth0/2
- ISP
router bgp 1
bgp router-id 1.1.1.1
network 1.1.1.1 mask 255.255.255.255
neighbor 100.100.100.2 remote-as 2
neighbor 100.100.100.6 remote-as 2
Best regard,
Hello @goyourmin ,
if the use of a dynamic routing protocol is not possible the configuration of static routes need to be careful to avoid issues with possible routing loops and with excessive ARP activiity.
a)    ARP activity when using a
without an IP next-hop
A static route like the following one:
makes the local device to make an ARP request for each different destination in the internet instead of resolving the IP next-hop once. So if you have 10,000 different destinations you will have 10,000 ARP entries in the ARP table all of them resolving to the ISP router interface MAC address. This is a waste of  resources and it can lead to problems if the ARP table size is too big.
So you need to use static routes where you use IP next-hops. I hope this point is clear now.
b) configuring static routes in a redundant environment requires attention to avoid possible routing loops
With the configuration that you have proposed there is a potential for routing loops
Your proposed config is the following:
- L3-switch-1
ip route 0.0.0.0 0.0.0.0 eth0/0 172.16.0.2
- L3-switch-2
ip route 0.0.0.0 0.0.0.0 eth0/0 172.16.0.1
Configuration on L3 switch 1 should be :
ip route 0.0.0.0 0.0.0.0 eth0/3 100.100.100.1
ip route 0.0.0.0 0.0.0.0 eth0/0 172.16.0.2  100
the second static route must be floating in order to  be used only  when primary route is removed from routing table ( link to ISP router fails)
With your current proposed configuration you have two static routes on
L3switch-1
one pointing to ISP router and one pointing to the neighbor
L3Switch-2
but they are both used.
Depending on CEF load balancing decisions on
L3switch-1
if a packet is sent to
L3 switch-2
using the second
default route, L3switch-2
will send it back to
L3Switch-1
that will send it again to
L3switch-2
because the load balancing decision is based on an hash of IP source address and IP destination address,  but it does not consider the input interface.
So you have a routing loop and you can solve it by making the route to
L3 switch2
floating ( adding an AD value greater then 1, 100 as in my example)
c)  other considerations on your lab
In real world the ISP router would send a
default route
in BGP to the eBGP neighbors, with your current setup this does not happen and you use
default static routes on L3Switch-1 and  L3switch-2
On router ISP you can advertise a
default route
in BGP
you need
ip route 0.0.0.0.0 0.0.0.0 A.B.C.D
router bgp 1
network 0.0.0.0
At this point you can remove the
on
L3switch-1 , L3switch-2
toward ISP router and you can add an iBGP session between them
L3-switch1
route-map RISE-PREF permit 10
set preference 200
router bgp 2
neighbor 100.100.100.1 route-map RISE-PREF in
neighbor 172.16.0.2 remote-as 2
L3 switch-2
router bgp 2
neighbor 172.16.0.1 remote-as 2
and you can remove also the floating static routes pointing to each other.
L3switch-2
will select the iBGP path from
L3switch-1
for the higher local preference 200 over the
eBGP route via ISP router
Hope to help
Giuseppe
Giuseppe Larosa
Hello @goyourmin ,
there are several notes about your configuration
a)  your static routes do not use IP next-hops and they rely on proxy ARP to be enabled on the neighbors. Use IP next-hops this avoid a lot of issues with excessive ARP usage specially for the
b)
on routers having eBGP sessions with ISP router you should use a
route-map
when redistributing static routes in order to avoid to
redistribute the default static route
to the ISP router
c)
Your topology is not able to handle link failures because it uses static routes you should use an IGP like OSPF or EIGRP in order to build a dynamic fault tolerant routing domain
Hope to help
Giuseppe
Thank you for your answer.
However, there is no alternative to this static configuration in the environment. (Dynamic protocol not supported)
If so, is it possible to configure the
default static root
for interlink between
L3-Switch-1 <-> L3-Switch-2
Example)
- L3-switch-1
- L3-switch-2
Hello @goyourmin ,
- L3-switch-1
- L3-switch-2
L3switch-1
L3Switch-2
L3switch-1
L3 switch-2
using the second
L3Switch-1
L3switch-2
L3 switch2
default route
default route
in BGP
you need
router bgp 1
network 0.0.0.0
on
L3-switch1
set preference 200
router bgp 2
L3 switch-2
router bgp 2
L3switch-2
L3switch-1
Hope to help
Giuseppe
