How to config the SG350 inter vlan (sharing VLANs with another router) ?
DijkrSw
Hello, I'm configuring my network, but I don't know how to setup the routing. I do have a Cisco SG350.
On both the R1 (PfSense) and R2 (SG350) I setup VLANs. The VLANs at R1 and R2 are in the same subnet. I only changed the IPs for the gateway, as you can see in the diagram below. What happen now, is that R1 routes all the inter vlan traffic. It also provides Host 1 and Host 2 a IP by DHCP. But more important to me, traffic from VLAN 100 visit R1, and not send traffic directly to VLAN 200. I've been using a video to config the SG350. I did exactly the same. What can I do to have the SG350 routing inter vlan traffic?
DijkrSw
Meanwhile, I've solved this. Because I also created VLANs at R1, and used a trunkport at R2 to allow the VLANs, it still routed inter VLAN traffic with R1. So by just deleting / deactivate the VLANs at R1, R2 started to route inter vlan traffic.
