How to configure 1 VWIC-2MFT-G703 and 1 VWIC-1MFT-G703 on 2821
befdefender
Hi everybody,
i have a 2821 equipped with 1 VWIC-2MFT-G703 and 1 VWIC-1MFT-G703.
I use these modules to receive data from three different sources and then i have to forward all the data received on G703 IFs over ethernet port.
How can i configure these modules?
Thanks in advance,
Enrico
paolo bevilacqua
You use IP routing and related commands, if you never used a cisco before, give the job to a consultant, you will save much time and frustration.
