How to Configure Cisco 7204 for the Internet
ThomasMull9000
Dear Cisco Fans
Today we got a new cisco 7204 with NPE-G2 , so we wanna to configure to root for the internet so here is my scenerio
1- Public Ip address -- 155.155.155.20
2 Private Ip Address - 192.168.2.0 /24
3- Gateway =           155.155.155.1
4-DNS Server =          194.155.12.133
Interfaces
1- Gigabite 0/1  - We put this for Public ip address
2- Gigabite 0/2 - and this for Private Ip address
so can any one help me how to route this for the internet . after routed we want our client computers to get internet from Gigabite 0/2 Interface
thank you very Much
Thomas, this router is in boot mode, its kind of a mini IOS with limited functionality...
As Rupert mentioned, you need to reload the router so that MAIN IOS can boot up, or atleast see what is happening why its not booting the main IOS file. Do change the config register value as Rupert mentioned in his post and when the router boots up completely, you should not see this (boot) in front of your prompt
8 Replies 8
Neeraj Arora
Level 3
Level 3
Try the following config, fill all the x's mentioned below:
config t
ip name-server 194.155.12.133
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
int gig0/1
description ISP/Internet facing link
ip address 155.155.155.20 255.255.255.x
ip nat outside
int gig0/2
description Inside LAN
ip address 192.168.2.1 255.255.255.0
ip nat inside
ip route 0.0.0.0 0.0.0.0 155.155.155.1
ip nat inside source list 100 interface gig0/1 overload
Connect a switch to gig0/2 and then connect your clients to that switch, assign ip address to these clients and use default gateway as 192.168.2.1, configure DNS server as mentioned. Internet should work on them
Hope it helps
Neeraj
thank You very much for your quick answer Narej aror
but the problem
ip route : this command is not recongised by Cisco 7204 .so what is problem please.
Thomas I seriously doubt that a 7204 router does not recognise "ip route" command
I think you need to check which prompt are you typing this command...lemme give you the above config with some changes so that prompt is not an issue:
router#config t
ip routing
int gig0/1
ip nat outside
no shut
exit
int gig0/2
ip nat inside
no shut
exit
exit
* I have added few exit & "ip routing" commands in the config, now try and see if you are able to add the ip route command. In case it still does not work, provide the snippet for that, what exact error do you get
Dear Neeraj thank you very much for you respond
i try to figure out the command Ip route
missing commands
- ip route :  Not recongised command
-ip nat outside /inside : Not recogised command
we have other routers like cisco 2801 , i configured the same you gave me , they are working fine and recongised all commands you posted .
cisco(boot)config#
so i doubte (boot) what that means , is that denying this commands
thank you
rupertsedgwick
conf t
Config-register 0x2102
Exit
Reload
Now try
Thank you for your help
conf t
Exit
Reload
has no change at all
so do i need to change the IOS image of the router
when the router is booting up, do you see any error message while the IOS is decompressing?
can you paste the output of following commands:
- sh file system
- sh flash
- sh disk0
- sh run | in boot
- sh ver
- boot capture of the screen, if possible through console connection
