09-10-2023 06:35 AM
vpc downstream devices only need configure feature lacp , then port channel no need further command to configure
how about VSS case?
how to configure downstream routers to use uplink devices which VSS?
09-10-2023 11:30 AM - edited 09-10-2023 11:31 AM
VSS General LACP config should work
vPC you only need on Nexus side - other side just standard LACP active should work.
Depends on Router and mode and IOS code running it, command may vary but concept is same.
BB
Log in to Community
