Showing results forĀ
Search instead forĀ
Did you mean:Ā
how to configure frame-relay timers
i have two routers connected with fram-relay, when i shut one link of router A then  router B Dcli should down in 3-5 seconds. when no shut then vice versa..
regards,
syed kazim abbas
Hi all,
actully , i want to ask keeplive end to end in frame-relay, i have sloved this problem.
thanx ,
kazim
Hello Kazim,
I am not sure if you are saying that you have solved this issue. In any case, this document might be interesting for you.
http://www.cisco.com/en/US/docs/ios/12_0t/12_0t5/feature/guide/FRKeep.html
Best regards,
Peter
Peter,
thanx, really it is useful and interesting l for me.
Best regards,
kazim
