How to configure multiple range port forwarding?
shinya hiura
Hello everyone!
I am facing critical issue for multiple range and destination of port forwarding.
I would like to configure NAPT as below.
LAN destination addresses                         WAN address
192.168.0.102  port range 16000 16511        10.0.0.1    port range 16000 16511
192.168.0.103  port range 16512 17023        10.0.0.1    port range 16512 17023
192.168.0.104  port range 17024 17535        10.0.0.1    port range 17024 17535
192.168.0.105  port range 17534 18047        10.0.0.1    port range 17534 18047
I have tried as following config, but it doesn't work.
ip nat pool POOL1 192.168.0.102 192.168.0.102 netmask 255.255.255.0 type rotary
ip nat pool POOL2 192.168.0.103 192.168.0.103 netmask 255.255.255.0 type rotary
ip nat pool POOL3 192.168.0.104 192.168.0.104 netmask 255.255.255.0 type rotary
ip nat pool POOL4 192.168.0.105 192.168.0.105 netmask 255.255.255.0 type rotary
ip nat inside destination list 101 pool POOL1
ip nat inside destination list 102 pool POOL2
ip nat inside destination list 103 pool POOL3
ip nat inside destination list 104 pool POOL4
access-list 101 permit udp any any range 16000 16511
access-list 102 permit udp any any range 16512 17023
access-list 103 permit udp any any range 17024 17535
access-list 104 permit udp any any range 17536 18047
I also tried route-map configuration, but result is same.
Do someone have same issue?
I will wait for kindly advice.
Shinya
このメッセージは次により編集されています: shinya hiura
Hello everyone,
I am still trying configuration about this, but it doesn't solve so far.
Do someone have correct solution?
9 Replies 9
jowen3400
I am having the same issue.  But you said your wan address is a 10.? are you trying to route a 10. address? is this this set up as a VPN.
I am trying this test in my lab.
10.0.0.1 is temporally address, I am not using actual public address.
cadet alain
the rotary pools only work with TCP traffic.
Alain
Hi Alain,
Do you know how to set the udp port range up?
Shinya
Hi Peter,
I already tryed following config, but the router didn't accept second source IP and same destination IP like this.
ip nat inside source static 192.168.0.102 10.0.0.1 route-map NAT
Router could not accept this line -->ip nat inside source static 192.168.0.103 10.0.0.1 route-map NAT
access-list 101 permit  udp host any range 16000 16511 any
access-list 102 permit  udp host any range 16512 17023 any
route-map NAT1 permit 10
match ip add 101
route-map NAT2 permit 10
match ip add 102
I already saw below site but not solved my issue.
http://evilrouters.net/2010/05/25/port-forwarding-a-range-of-ports-on-cisco-ios/
Hiura
My test is successful:
ip nat pool PORTFWD2 192.168.0.102 192.168.0.102 netmask 255.255.255.0 type rotary
ip nat pool PORTFWD3 192.168.0.103 192.168.0.103 netmask 255.255.255.0 type rotary
access-list 102 permit udp any any range 16000 16511
access-list 102 permit tcp any any range 16000 16511
access-list 103 permit udp any any range 16512 17023
access-list 103 permit tcp any any range 16512 17023
ip nat inside destination list 102 pool PORTFWD2
ip nat inside destination list 103 pool PORTFWD3
int f0/0
ip address 10.0.0.1 255.255.255.0
no shut
ip nat outside
int F0/1
ip address 192.168.0.1 255.255.255.0
no shut
ip nat inside
R1#sh ip nat translations
Pro Inside global     Inside local       Outside local     Outside global
tcp 10.0.0.1:16100     192.168.0.102:16100 10.0.0.2:12654   10.0.0.2:12654
tcp 10.0.0.1:16800     192.168.0.103:16800 10.0.0.2:53244   10.0.0.2:53244
Hi Peter,
Thank you for your advice.
I already tested that.
It only works for TCP, UDP is not able to forward by such configuration.
Show IP nat translation shows tcp without udp.
I am realy in trouble.
Hiura
Well, you are right.
