Why is s0/0.1 down?
gergokarpati
Dear All,
Recently my lab did grind my gears and I simply cannot figure it out why my frame-relay config wont work.
This is the topology I use.
R1 Uses a Multipoint S0/0.1 interface and OSPF works fine in the area with routers R2 and R3.
R1:
R1#sh frame-relay map
Serial0/0.1 (up): ip 10.0.0.2 dlci 102(0x66,0x1860), static,
              CISCO, status defined, active
Serial0/0.1 (up): ip 10.0.0.3 dlci 103(0x67,0x1870), static,
Serial0/0.1 (up): ip 10.0.0.4 dlci 104(0x68,0x1880), static,
R4:
R4#sh frame-relay map
Serial0/0.1 (down): point-to-point dlci, dlci 401(0x191,0x6410), broadcast
          status defined, inactive
R4#sh ip ospf interface
Serial0/0.1 is down, line protocol is down
  Internet Address 10.0.0.4/24, Area 0
  Process ID 1, Router ID 4.4.4.4, Network Type POINT_TO_POINT, Cost: 64
  Transmit Delay is 1 sec, State DOWN
  Timer intervals configured, Hello 20, Dead 80, Wait 80, Retransmit 5
    oob-resync timeout 80
R4#sh run:
interface Serial0/0
no ip address
encapsulation frame-relay
clock rate 2000000
interface Serial0/0.1 point-to-point
ip address 10.0.0.4 255.255.255.0
ip ospf hello-interval 20
frame-relay interface-dlci 401
from the sh run one can see that the s0/0.1 should be up.
R4#sh ip int br
Interface                  IP-Address      OK? Method Status                Protocol
FastEthernet0/0            unassigned      YES unset  administratively down down
Serial0/0                  unassigned      YES unset  up                    down
Serial0/0.1                10.0.0.4        YES manual down                  down
FastEthernet0/1            unassigned      YES unset  administratively down down
any ideas/help would be appreciated!
Thanks in advance!
cadet alain
your main interface is up/down so that's why your subinterface is down/down.
Can you post your FR switch config.
Alain
cadet alain
Alain
Hi Alain!
Thanks for drawing my attention to it! after several times of shut/no shut I did add a new FRS and remapped the dlci-port allocation and with the new one it works...
guess more likely GNS3 related.
Anyways I misse the up/down severaltimes...
Thanks for the help!
