How to configure rate limit in catalyst 2960
hiromushi
We have Catalyst 2960, we must limit the input output interfaces at a constant rate (eg 40Mb / s). rate-limit function is not currently supported, is what you intend to change the ios for the function is supported?
if not, how I can do to meet this need?
thank you for your reply
Giuseppe Larosa
hello David,
by using QoS you can  limit outbound
see
http://www.cisco.com/en/US/docs/switches/lan/catalyst2960/software/release/12.2_53_se/configuration/guide/swqos.html#wp1253412
This example shows how to limit the bandwidth on a port to 80 percent:
Switch(config)# interface gigabitethernet0/1
Switch(config-if)# srr-queue bandwidth limit 80
I'm afraid nothing can be done for inbound
Hope to help
Giuseppe
u1kumar2002
    Agreed to above answer. For more information Plz vist : http://startnetworks.blogspot.com/2010/08/rate-limit-on-switches.html
Here you can find with examples and some more ways.
Do rate for helpful posts...
Uttam
