07-02-2012 08:26 AM - edited 03-04-2019 04:51 PM
We've just invested in a pair of Sup2Ts to upgrade a Sup720 6509 chassis but I'm unsure exactly how the management port(s), aka the
Connectivity Management Processor (CMP), should be configured (and patched) in a dual supervisor system?
Is each CMP an independent entity or is the management interface configuration (IP address, gateway, etc) replicated between supervisors?
If it's the latter then do both management ports need to be physically connected at the same time?
Thanks in advance
Matthew
Solved! Go to Solution.
07-02-2012 08:42 AM
CMP should be treated as a separate entity and there is no replication of such information between supervisors.
For more information, please refer to the documentation:
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/cmp_configuration/guide/cmp_overview.html
07-02-2012 08:42 AM
