How to configure the link aggregation on layer 3 switch?
ssweehinlew
How to configure the link aggregation on layer 3 switch and disable spanning tree? Can show me sample? for example, 2 ports from switch A to 2 ports of switch B.
5 Replies 5
Leo Laohoo
Below is the configuration from the switch. The etherchannel summary is showing the status (SD). Should I put SW2(config-if-range)# no switchport? Port 1 and 2 are the trunk ports.
SW1# configure terminal
SW1(config)# interface port-channel 1
SW1(config-if)# end
SW1(config)# interface range gigabitethernet1/1 -2
SW1(config-if-range)# channel-group 1 mode on
SW1(config-if-range)# end
SW2# configure terminal
SW2(config)# interface port-channel 1
SW2(config-if)# end
SW2(config)# interface range gigabitethernet1/1 -2
SW2(config-if-range)# channel-group 1 mode on
SW2(config-if-range)# end
EtherChannel you need it is L3 (mean use IP address)
Or L2 EtherChannel
Then there are 3 protocols you can use it: LACP, PaGp, Static
Let me know to provide you all configuration
Any question please ask
It will be good if you can provide me sample etherchannel L2 configuration (without IP address) and etherchannel L3 configuration on trunk port. It has spent me the whole day to try it out. Thanks.
Ok ,
Etherchannel :
LACP: Standard Protocol --- have two modes Active and Passive
PagP : Cisco Property  ---- have two mode Auto and Desirable
On     : Static
You can read about it for more info
L2 Channel Group Configuration using LACP (Link Aggregation Control Protocol) and Trunk:
Sw 1 connect to Sw2
Sw1 Ports F0/1 - F0/2
Sw2 Ports F0/1 - F0/2
Sw 1 Configuration :
First make sure the interfaces returned to default by using :  default inter f0/1
Interface range F0/1 - 2
Shutdown
Channel-group 1 mode Active
Exit
Inter PO 1
Switchport mod trunk
Switchport trunk encap dot1q
And you can use any configuration
Keep the ports Shutdown
Sw 2 Configuration:
Shutdown
Channel-group 1 mode Passive
Exit
Inter PO 1
Switc port trunk encap dot1q
Now do no shutdown for to interfaces.
For troubleshooting:
show channel summ
show span vlan 1 ( must STP see the port channel (Po1) not F0/1 and F0/2 )
L3 Channel Group Configuration using LACP (Link Aggregation Control Protocol)
Sw 1 Configuration:
interface range F0/1 - 2
no switchport ---- to act as L3 port
shutdown
channel-group 1 mode Active
exit
inter PO 1
ip address XXX.XXX.XXX.XXX
and you can use any configuration
keep the ports Shutdown
Sw 2 Configuration :
shutdown
exit
inter PO 1
now do no shutdown for to switches
the traffic will send it over the two links (Load Balance)
