How to connect to the internet with cisco 891F?
tomo456
WAN port:G8
LAN port:G1
PING between the LAN port(G1) and this router arrives.
I sent a PING from the router to an external address, but no reply.
I think that something is wrong with WAN (G8) configuration.
"show run" of this router
version 15.4
hostname test
boot-start-marker
boot-end-marker
enable password test
no aaa new-model
no ip dhcp conflict logging
ip dhcp excluded-address 192.168.10.1 192.168.10.100
ip dhcp pool DHCP_pool
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
dns-server 192.168.10.1
lease 0 2
ip cef
no ipv6 cef
cts logging verbose
license udi pid C891FJ-K9 sn FGL222995KP
vtp domain rt1
vtp mode transparent
vlan 2-4,8-10,20,30,111
no cdp run
interface Loopback0
no ip address
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
no ip address
shutdown
duplex auto
speed auto
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
switchport access vlan 10
no ip address
interface GigabitEthernet2
no ip address
shutdown
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
shutdown
interface GigabitEthernet5
no ip address
shutdown
interface GigabitEthernet6
no ip address
shutdown
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface Vlan1
no ip address
ip tcp adjust-mss 1452
interface Vlan10
ip address 192.168.10.1 255.255.255.0
ip nat inside
ip virtual-reassembly in
interface Async3
no ip address
encapsulation slip
interface Dialer1
mtu 1454
ip address negotiated
ip nat outside
encapsulation ppp
ip tcp adjust-mss 1414
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname test@test.com
ppp chap password 0 password
ppp ipcp dns request accept
no cdp enable
no ip forward-protocol nd
no ip http server
no ip http secure-server
ip dns server
ip nat inside source list acl_NAT interface Dialer1 overload
ip route 0.0.0.0 0.0.0.0 Dialer1
ip access-list standard acl_NAT
permit 192.168.10.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
vstack
line con 0
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
password test
login
transport input none
scheduler allocate 20000 1000
end
Hello
WAN port:G8
LAN port:G1
So you cannot ping externally from the router or from the lan ?
Do you receive an ip address from the ppoe server.
vpdn enable
vpdn-group 1
request-dialin
protocol pppoe
int gig0/8
ip nat outside
sh ip int brief | in up
sh pppoe sessions
Kind Regards
Paul
