Routing vlan traffic into IPIP tunnel
RemRem
Greetings,
So, I have traffic from the LAN side:
interface GigabitEthernet0/0/1.10
 encapsulation dot1Q 10
 ip dhcp relay information trusted
 ip address 10.x.x.x 255.255.255.192
 ip helper-address 10.y.y.y
 ip policy route-map mymap
that needs to be routed into this tunnel:
interface Tunnel0
 ip unnumbered GigabitEthernet0/0/1
 ip tcp adjust-mss 1332
 tunnel source GigabitEthernet0/0/0
 tunnel mode ipip
 tunnel destination 81.a.a.a
 tunnel path-mtu-discovery
route-map mymap permit 10
 set interface Tunnel0
ip route 0.0.0.0 0.0.0.0 217.b.b.b.b
ip route 10.0.0.0 255.0.0.0 Null0
ip route 10.r.r.r 255.255.255.0 Tunnel0
ip route 10.s.s.s 255.255.255.0 Tunnel0
ip route 10.t.t.t. 255.255.255.0 Tunnel0
This setup works as long as I don't use dot1q subinterfaces. With subinterfaces it only works if I use a vrf.
Can this be done without using vrfs?
5 Replies 5
Hello
@RemRem wrote:
Greetings,
interface Tunnel0
 tunnel mode ipip
Route-map mymap permit 10
No set interface tunnel 0
set is next-hop 8.a..a.a
Kind Regards
Paul
I tried the route-map with set ip next-hop instead of set interface but I still can't reach the 10. nets at the other end of the tunnel.
Hello
Why do you have a null static for that subnet?
Remove the policy-route from the interface and also the null route, test again..
no ip route 10.0.0.0 255.0.0.0 Null0
no ip policy route-map mymap
Kind Regards
Paul
The Null route drops all traffic to the 10.0.0.0/8 net that is not routed to the specified nets from the other static routes.
I removed it but it made no difference. Same for removing the route-map from the interface GigabitEthernet0/0/1.10.
Hello
Do you have reachability over the tunnel - can you ping the tunnel destination
Kind Regards
Paul
