12-16-2024 03:58 AM - edited 12-16-2024 04:01 AM
We want to isolate PC1 and PC2.
PC1 and PC2 are not subject to the ACL because they are in the same network.
Is a Private vlan appropriate?
Any ideas?
Solved! Go to Solution.
12-16-2024 03:59 AM
12-16-2024 10:32 PM
ip access-list extended allow
 permit ip host 144.144.144.10 host 144.144.144.1
 permit ip host 144.144.144.20 host 144.144.144.1
permit ip host 144.144.144.1 host 144.144.144.10
permit ip host 144.144.144.1 host 144.144.144.20add additional two line for return back traffic
MHM
12-16-2024 03:59 AM
use VLAN acces-list
MHM
12-16-2024 04:00 AM
12-16-2024 04:00 AM
I have configured ACLs to VLANs, but same-band L2 frames are not subject to ACLs.
12-16-2024 04:07 AM
share the config please
MHM
12-16-2024 04:47 AM - edited 12-16-2024 04:51 AM
The VACL you mentioned was worth a try.
I want to deny all networks on 144.0/24 and permit the 144.1 IP, which is the gateway.
I don’t know if my config is correct, but pinging to the gateway fails.
The match count for all ACLs on 144.1/32 and 144.0/24 is incremented.
access-list 101 permit ip any host 144.144.144.1
access-list 100 permit ip any 144.144.144.0 0.0.0.255
vlan access-map vacl 10
match ip address 101
action forward
vlan access-map vacl 20
match ip address 100
action drop
vlan access-map vacl 30
action forward
vlan filter vacl vlan-list 144VPCS> ping 144.144.144.1
144.144.144.1 icmp_seq=1 timeout
144.144.144.1 icmp_seq=2 timeout
144.144.144.1 icmp_seq=3 timeout
BB#sh access-list
Extended IP access list 100
10 permit ip any 144.144.144.0 0.0.0.255 (23 matches)
Extended IP access list 101
10 permit ip any host 144.144.144.1 (23 matches)
12-16-2024 04:53 AM
try below
match ip address 200 <<- where ACL200 permit traffic between two host
action deny LOG
action forward
12-16-2024 05:09 AM - edited 12-16-2024 05:12 AM
BB(config)#vlan access-map vacl 10
BB(config-access-map)# match ip address 200
% Invalid access list name.
where ACL200 permit traffic between two host ??
I only want to permit gateway
12-16-2024 05:15 AM
access-list 200 permit ip host 144.144.144.10 host 144.144.144.20
use this ACL, and for GW since it not permit by 200 and action deny then it will permit
MHM
12-16-2024 05:31 AM - edited 12-16-2024 05:33 AM
access-list 199 permit ip host 144.144.144.10 host 144.144.144.20
 match ip address 199
 action drop log
 action forward
Since ACL number 200 is not available, I used 199.
The ping to the gateway was successful and the hosts blocked pinging each other.
But I want to block the entire 144.0/24 network.
I need some good ideas.
12-16-2024 05:39 AM
sorry for the ACL number
NOW first issue solve deny traffic between the two host
you need to block traffic between host and entire 144.144.144.0/24
then
action forward
ip access-list ext P2P
permit ip host 144.144.144.10 144.144.144.0 0.0.0.255
permit ip host 144.144.144.20 144.144.144.0 0.0.0.255
action deny log
lastly you need line 30 for other traffic
goodluck friend
MHM
12-16-2024 10:26 PM - edited 12-16-2024 10:31 PM
ip access-list extended P2P
 match ip address allow
 action forward
 match ip address P2P
 action drop log
VPCS> show
NAME IP/MASK GATEWAY GATEWAY
VPCS1 144.144.144.10/24 144.144.144.1
fe80::250:79ff:fe66:6807/64
VPCS> ping 144.144.144.20
144.144.144.20 icmp_seq=1 timeout
144.144.144.20 icmp_seq=2 timeout
It cannot ping to 144.1.
Because 144.0/24 contains 144.1.
What do you think, is there a better way?
12-16-2024 10:32 PM
MHM
12-17-2024 12:40 AM
 match ip address 10
 action forward
 action drop log
*Dec 17 07:42:31.536: %VLMAPLOG-6-ICMP: vlan 144 (port Gi0/0) denied icmp 144.144.144.10 -> 144.144.144.20 (8/0), 1 packetVPCS> show
84 bytes from 144.144.144.1 icmp_seq=1 ttl=255 time=7.801 ms
84 bytes from 144.144.144.1 icmp_seq=2 ttl=255 time=4.608 ms
144.144.144.20 icmp_seq=2 timeoutNICE
12-17-2024 12:40 AM
Hello @MHM Cisco World @JustTakeTheFirstStep
FYI - you do not need to permit the gateway, each host internal to the filtered vlan should still able to reach externally, i have posted an example above that should accommodate the OPs initial request
