How to deny the same network L2 layer?
We want to isolate PC1 and PC2.
PC1 and PC2 are not subject to the ACL because they are in the same network.
Is a Private vlan appropriate?
Any ideas?
23 Replies 23
VACL is filter inter and intra VLAN traffic.
he need to make host reach the GW to connect to other subnet
MHM
Hello @MHM Cisco World
MHM
Inter-vlan traffic will still work
Kind Regards
Paul
@JustTakeTheFirstStep
Private vlan or Mac access list
Hello
VACLS/PVLANs are both ways of negating connectivity between multiple host within the same vlan however for just a single PC-PC
you can use a protected port
PC1 & PC2
int x/x
switchport protected
Kind Regards
Paul
Hello
Yeah apologies..I realised after i posted your OP has switch interconnects, it does only work hosts on the same switch its a little one to beware of in case such a need cases arises ( depending that if the switch ios supports it, as its a rather old feature)
Kind Regards
Paul
Hello
FYI- by default there is a deny stanza in vacls so all you need in this instance to append a manual drop action and permit everything else
Try the following:
access-list 100 permit ip 144.144.144.0 0.0.0.255 144.144.144.0 0.0.0.255
vlan access-map VACL
match ip address 100
action drop
vlan access-map VACL 100
action forward
vlan filter VACL vlan-list 144
Kind Regards
Paul
@paul driver
But the gateway is still denied.
Test was successful as per MHM's answer
Thank you very much for your continued interest.
Hello
you do not need to reach the gateway it will still work (intervlan routing ) that is for the filtered vlan 144
Kind Regards
Paul
