How to enable Auto VC configuration in ATM interface?
vijaykarthiks
I am trying to auto provision a cisco 2600 CPE with ATM/IMA links using ILMI. This CPE is connected to a DSLAM. Basic ATM interface parameters are successfully exchanged using ILMI. However, the PVC configurations in the DSLAM are not trasnferred to the CPE through ILMI.
When I do a "sh int atm1/0" in the CPE, I see that "VC Auto creation Disabled".
How can I enable VC auto creation on this interface? I don't see any command to enable this feature. Please let me know.
Vijay
Note: I enabled ilmi-pvc-discovery on that interface, but the VC Auto Creation is disable always.
7 Replies 7
imranmohd
Hi Vijay
Try this Url
http://www.cisco.com/en/US/products/sw/iosswrel/ps5012/products_feature_guide09186a0080140037.html#wp1024430
Also try the following commands
Router(config)#network change participate wic 0 or
Router(config)#networ clock source e1 0/1
Do rate if works.
Thanks for the response Imran.
I already tried the options mentioned in the link that you sent. However, I could not see 'create on-demand' command in my 2621 CPE.
I don't see the network commands either.
Vijay
Dear Vijay,
Pls try putting following commands on your router.Hope this work
controller E1 0/0
mode atm aim 0
controller E1 0/1
mode atm aim 0
(router)#network-clock-participate wic 0
(router)#network-clock-participate wic 1
(router)#network-clock-participate aim 0
(router)#network-clock-select 1 E1 0/0
(router)#network-clock-select 2 E1 0/1
Under global configuration u need to create an ATM/AIM interface in the following way.
interface ATM0/0
description --- XNR= DNA= MTN Port=
no ip address
mtu 1500
no ip address
no ip redirects
no ip proxy-arp
no atm auto-configuration
no atm ilmi-keepalive
no atm address-registration
no atm ilmi-enable
interface ATM0/1
no ip address
mtu 1500
no ip address
no ip redirects
no ip proxy-arp
no atm ilmi-enable
interface ATM0/IMA0
description --- XNR= DNA=MTN Port=
mtu 1500
no ip address
no ip redirects
no ip proxy-arp
ip route-cache flow
load-interval 30
no atm ilmi-enable
Dear Imran,
Thanks for the response. I tried the commands similar to the one you gave, but I still cannot get 'create on-demand' commands in the CLI for PVC configuration. May be I have the wrong IOS. Mine is 12.3(18).
In the configuration you sent, ILMI is disabled. But I need ILMI to be enabled for my testing. After enabling ILMI, I could see ATM interface parameters being exchanged successfully with the router.
After this PVC auto configuration is supposed to happen. But the PVC auto configuration is not happening. Such a request should come from router but i could not see it.
When I do a sh int atm 0/0, I see a line "VC Auto creation disabled". Do you know how to enable this? I enabled atm ilmi-pvc-discovery. But the VC Auto creation remains disabled in the sh atm command. I think PVC configuration is not happening because of this. If I can enable this, then probably PVC information will be sent from DSLAM to router over ILMI PDUs successfully.
Thanks for your response.
Vijay
Hi Vijay,
Please find the attachment i hope it will do.
Hi Imran,
Thanks for the information. I believe the pdf document is same as the link that you sent before. Those commands are available in my CPE.
Thanks for your assistance anyway.
Vijay
I am having the same issues. Could you repost the pdf file.
