Configure Route Dampening on GRE Tunnel interface
kjanakiraman
I would like to know if there are any good document available on the web for configuration of Route dampening for GRE Tunnel to switch to other tunnel if the active tunnel is flapping frequently.
Thanks in Advance
pkhatri
Level 11
Level 11
You might want to have a look here:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122newft/122t/122t13/ftipevdp.htm
Hope that helps - pls do remember to rate posts that help.
Paresh
