How to enable IP accounting in ISR4321/K9
deepak.nayak1
HI,
How to enable IP accounting in ISR4321/K9.
#sh ver
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved.  Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0.  The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY.  You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0.  For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
KGI-SEC-INTERNET uptime is 3 days, 15 hours, 20 minutes
Uptime for this control processor is 3 days, 15 hours, 21 minutes
System returned to ROM by reload at 19:45:57 IST Fri Dec 23 2016
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite                 Suite Current         Type           Suite Next reboot
FoundationSuiteK9     None                  None           None
securityk9
appxk9
AdvUCSuiteK9          None                  None           None
uck9
cme-srst
cube
Technology Package License Information:
Technology    Technology-package           Technology-package
              Current       Type           Next reboot
appxk9           appxk9           Permanent        appxk9
uck9             None             None             None
securityk9       securityk9       Permanent        securityk9
ipbase           ipbasek9         Permanent        ipbasek9
cisco ISR4321/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FDO1936A03V
2 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3223551K bytes of flash memory at bootflash:.
Amit Goyal
Hi Deepak,
I believe IP accounting is not supported on ISR4321 since it is equipped with IOS-XE. Please check below thread.
https://supportforums.cisco.com/discussion/12271776/isr-4451-ip-accounting-config
please rate if it helps.
-Amit
Amit is right on the money. IOS-XE devices do not support IP Accounting. As far as I remember, it has been replaced with Flexible NetFlow:
Flexible NetFlow Configuration Guide, Cisco IOS XE Release 3S
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fnetflow/configuration/xe-3s/fnf-xe-3s-book/fnf-fnetflow.html
