Showing results forĀ
Search instead forĀ
Did you mean:Ā
L2TP issue between 7206 and 2911
hello all
i did in past a lot of L2TP connection between two end point.
in this case ans with 2911 series with ios 15 and DATA license Activated.
i The l2tp session does not establishe between a this 2911 and 7209.
please FIND attached the topologie file and bellow the  configuration of both router.
regards.
PE 2911
l2tp-class l2-dyn
authentication
password 123456
cookie size 8
pseudowire-class pw-dynamic
encapsulation l2tpv3
sequencing both
protocol l2tpv3 l2-dyn
ip local interface GigabitEthernet0/0
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
no cdp enable
xconnect <ip of GI 0/0 of 7209> 999 pw-class pw-dynamic
show l2tp session outpoot
L2TP Session Information Total tunnels 1 sessions 1
LocID      RemID      TunID      Username, Intf/      State  Last Chg Uniq ID
                                 Vcid, Circuit
2777656560 0          3482209464 999, Gi0/2           wt-cc  00:00:13 13
PE 7206
l2tp-class l2-dyn
authentication
password 123456
cookie size 8
sequencing both
interface GigabitEthernet0/3
no ip address
duplex auto
speed auto
media-type rj45
negotiation auto
xconnect <ip of GI 0/0 of 2911> 999 pw-class pw-dynamic
                                 Vcid, Circuit
56720      0          7193       999, Gi0/3           wicrp  00:00:41 508
kert dezcom
Hello, we have the same issue between 2911 and 3825 with l2tpv3. Dynamic tunnel didn't become up, but use manual tunnel and it's working.
i.e.
R1:
pseudowire-class pwclass
protocol none
ip local interface Loopback0
interface GigabitEthernet0/1.316
encapsulation dot1Q 316
no cdp enable
xconnect x.x.x.x 316 encapsulation l2tpv3 manual pw-class pwclass
  l2tp id 2001 1002
  l2tp cookie local 4 201
  l2tp cookie remote 4 102
end
R2:
interface GigabitEthernet0/1.500
encapsulation dot1Q 500
no cdp enable
xconnect y.y.y.y 316 encapsulation l2tpv3 manual pw-class pwclass
  l2tp id 1002 2001
  l2tp cookie local 4 102
  l2tp cookie remote 4 201
end
Hi All,
i got a cisco 2911 cisco router.
i cannot configure pseudowire-class pwclass on the cisco 2911 router.
the router image is below
IOS Image: c2900-universalk9-mz.SPA.152-4.M5.BIN
could any one assist please.
kind regards,
Wilson
To configure L2tpv3 on your c2911 you need the feature datak9 to be active.
verify by doing the # show license command. If showing "not Active" try this link to learn more about enabling the evaluation.
http://www.cisco.com/c/en/us/td/docs/routers/access/sw_activation/SA_on_ISR.html
