09-04-2012 03:03 AM - edited 03-04-2019 05:27 PM
Hi All,
Please help me for Enabling
IP Accounting or capture packets in Cisco ASA 5510 ( 8.2 ).
Roopesh
Solved! Go to Solution.
09-04-2012 06:57 AM
Hi Roopesh,
Create an access-list with source destination ip address and/or tcp/udp ports
then use it
capture CAP_NAME access-list ACL_NAME buffer 12345bytes interface INT_NAME
You can check the capture
show capture ?
WORD Capture name
| Output modifiers
Take care,
PaulC
09-04-2012 03:16 AM
You need to move the post to security:
https://supportforums.cisco.com/community/netpro/security
Kind Regards,
Ivan Shirshin
**Please grade this post if you find it useful.
09-04-2012 06:57 AM
Hi Roopesh,
then use it
show capture ?
WORD Capture name
| Output modifiers
Take care,
PaulC
