Is there a way to identify source of runts?
mmillington_nal
I am getting input errors/runts on 2 of my gigabit interfaces that connect to our WAN service provider's network. In relation to total packets, its not a large number, so its probably not a big deal, but I'd just like to find the source so I stop seeing the errors in Solarwinds. Our service provider says that they don't see any errors on their side, but the errors are incoming to us.
I've tried to capture the traffic with Wireshark, but discovered that often these packets are either discarded or padded by NICs so Wireshark will not see them, or at least will not see them as undersized.
Is there any other way I can capture these packets so I can find the source and figure out how to stop them? Our equipment is 3750G running 12.2(55)SE. Its not a trunk port. I know there was a bug in prior IOS that would cause some frames to be marked as runts even though they were forwarded successfully.
TIA,
Matt
Leo Laohoo
Hi Matt,
Can you post the output of the following commands:
1.  sh interface ;
2.  sh controller ether ; and
3.  sh version
FYI:  12.2(55)SE is an IOS train I would not recommend.  Use the "higher" train, 12.2(55)SE5 or SE6.
GigabitEthernet1/0/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet, address is 18ef.6330.9242 (bia 18ef.6330.9242)
  Description:
  Internet address is
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, media type is 10/100/1000BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  5 minute input rate 4980000 bits/sec, 602 packets/sec
  5 minute output rate 589000 bits/sec, 430 packets/sec
     5062338892 packets input, 4744772133149 bytes, 0 no buffer
     Received 2824877 broadcasts (1864097 IP multicasts)
     4308417 runts, 0 giants, 0 throttles
     4308417 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 2295884 multicast, 0 pause input
     3951823367 packets output, 1158349305808 bytes, 0 underruns
     Transmit GigabitEthernet1/0/1            Receive
   3006866293 Bytes                       3180871679 Bytes
   3951708752 Unicast frames               764594976 Unicast frames
       143969 Multicast frames               2295901 Multicast frames
         2965 Broadcast frames                528996 Broadcast frames
            0 Too old frames              2553158655 Unicast bytes
            0 Deferred frames              316965112 Multicast bytes
            0 MTU exceeded frames           33855744 Broadcast bytes
            0 1 collision frames                   0 Alignment errors
            0 2 collision frames                   0 FCS errors
            0 3 collision frames                   0 Oversize frames
            0 4 collision frames             4308449 Undersize frames
            0 5 collision frames                   0 Collision fragments
            0 6 collision frames
            0 7 collision frames           474595438 Minimum size frames
            0 8 collision frames          1079291391 65 to 127 byte frames
            0 9 collision frames           317273828 128 to 255 byte frames
            0 10 collision frames           68993847 256 to 511 byte frames
            0 11 collision frames          141786924 512 to 1023 byte frames
            0 12 collision frames         2984754190 1024 to 1518 byte frames
            0 13 collision frames                  0 Overrun frames
            0 14 collision frames                  0 Pause frames
            0 15 collision frames
            0 Excessive collisions                 0 Symbol error frames
            0 Late collisions                      0 Invalid frames, too large
            0 VLAN discard frames                  0 Valid frames, too large
            0 Excess defer frames                  0 Invalid frames, too small
   1626303732 64 byte frames                       0 Valid frames, too small
   1344583751 127 byte frames
    292402492 255 byte frames                      0 Too old frames
     59212555 511 byte frames                      0 Valid oversize frames
     84793240 1023 byte frames                     0 System FCS error frames
    544559916 1518 byte frames                     0 RxPortFifoFull drop frame
            0 Too large frames
            0 Good (1 coll) frames
            0 Good (>1 coll) frames
Cisco IOS Software, C3750 Software (C3750-IPSERVICESK9-M), Version 12.2(55)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Sat 07-Aug-10 22:45 by prod_rel_team
Image text-base: 0x01000000, data-base: 0x02F00000
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.2(44)SE5, RELEASE SOFTWARE (fc1)
flrlan-rpr uptime is 14 weeks, 1 day, 23 hours, 33 minutes
System image file is "flash:/c3750-ipservicesk9-mz.122-55.SE.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco WS-C3750G-24PS (PowerPC405) processor (revision H0) with 131072K bytes of memory.
Processor board ID FOC1424W2Y8
Last reset from power-on
1 Virtual Ethernet interface
28 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address       : 18:EF:63:30:92:00
Motherboard assembly number     : 73-10217-08
Power supply part number        : 341-0108-04
Motherboard serial number       : FOC142351WW
Power supply serial number      : DCA1422A07Q
Model revision number           : H0
Motherboard revision number     : C0
Model number                    : WS-C3750G-24PS-E
System serial number            : FOC1424W2Y8
Top Assembly Part Number        : 800-27482-02
Top Assembly Revision Number    : E0
Version ID                      : V06
CLEI Code Number                : COMXC00ARA
Hardware Board Revision Number  : 0x09
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24PS     12.2(55)SE            C3750-IPSERVICESK9-M
Configuration register is 0xF
Thank you Leo. What are the differences between the SE train and the SE5 or SE6 train? I've never really understood the differences in the trains.
-Matt
