How to enable 'show process cpu history table" feature?
cciesec2011
Level 3
Level 3
How does one go about enabling this feature below:
c3845#show process cpu history table
%CPU utilization history table is not enabled
c3845#
Thanks.
Ganesh Hariharan
c3845#
Thanks.
Hi ,
Configure the following commandsin router !!
process cpu statistics limit entry-percentage number [size seconds]
Example:
Router(config)# process cpu statistics limit entry-percentage 40 size 300
Sets the process entry limit and the size of the history table for CPU utilization statistics.
•In this example, to generate an entry in the history table, a process must exceed 40 percent CPU utilization.
•In this example, the duration of time for which the most recent history is saved in the history table is 300 seconds.
Hope to help !!
Ganesh.H
Can you please provide a screenshot for the output from this command?
thank you
R1#  sh proc cpu history table
CPU utilization for five seconds: 0%/0% at 00:05:35
R1#
