How to enabled audit log
ersin erol
Hi everyone,
  In our network we use cisco WS-C6509-E (R7000) Backbobe switch. We want to route syslog to log server.But I couldn't do it. How can solve this problem?
8 Replies 8
ersin erol
Any one help me ?
The command you need to add in the global context is logging where ip-addr is the IP address of one or more SYSLOG servers. In addition you can specify the source of the log messages with the logging source-interface such that irrespective of which interface the SYSLOG message is routed via, the SYSLOG server will see all messages originating from a single, consistent IP address.
There are other options with the logging command e.g., the level of the SYSLOG messages that will be sent. Let me know if you need any additional information.
I wrote these commands:
-logging on
-logging
are commans not enough ?
That's all that is required to send log messages to the SYSLOG server, and as can be seen from your extract, 16,060 messages have already been logged.
Do these messages not appear in your SYSLOG? Do you have a route toward the IP address you're using for the SYSLOG server. I assume you can ping the server from the router?
Steve,
you are right there are log files on switch. But these logs not appear on log server.I thought that maybe ; Because of "audit log disabled".
  On log server (ubuntu) I listen(tcpdump) logs but from backbone switch any log appear.
The audit disabled should not affect this.
Do you have logging source-interface command configured on this router such that all logging is sent from a known IP address i.e., that assigned to the loopback interface? If so can you ping the SYSLOG server using the command ping source and make sure you can see this traffic on your server with the command tcpdump host and icmp.
If you don't have the logging source-interface configured, can you run show ip route and check which interface(s) the traffic would take towards the server. Then run the same tcpdump command as above, but substitute the with the address of the interface from the show ip route above.
One other question. Do you use VRF on this router?
The_Nirvana
Hello Ersin,
You should start by deciding what IP on the switch you will use to represent the switch on the syslog server. (If your switch has only one IP address configured, it will use this IP by default). However, core switches usually have many IP addresses and your management VLAN interface is usually the one to choose.
Your syslog server should be able to reach the switch. By default, syslog uses UDP port 514. Traffic on these ports should be allowed in case there is an access-list or firewall in between your switch management vlan and the syslog server.
Note: You can manually configure the switch to send logs using a diffferent layer 4 (TCP or UDP) and on a customized port.
The first step is to enable the logging with the command:
R1(config)#logging on
Specify your syslog server
R1(config)#logging 10.1.1.1
You can change the transport layer protocol and the port
R1(config)#logging host 10.1.1.1  transport tcp port  59999
If your switch has more than one interfaces, you can choose which one will represent your switch
R1(config)#logging source-interface vlan100
You can also log any configuration changes done on the device by the various administrators in your team.
R1(config)#logging userinfo
R1(config)#archive
R1(config-archive)#log config
R1(config-archive-log-cfg)#logging enable
Usually you do not need to specify your device ip address in the syslog server. However, If you are using PRTG as your syslog server, you will need to add a sensor for your switch using the ip address you mentioned in the source-interface.
I hope this helps
Best Regards
Ashaan
