How to exit internet one vlan by diferent port
luisdivar
Hi Community. I have one switchcore and two ASA's. Each ASA has own link to internet and also each ASA connect to a different ISP.
I want to exit one vlan through one ASA and the other vlans by the other ASA. How can I do that?
Regards.
Deepak Kumar
Please past following configuration on your switch :
ip routing!
interface FastEthernet0/1
description connected to ASA 1
switchport access vlan 2
interface FastEthernet0/2
description connected to ASA 2
switchport access vlan 3
interface FastEthernet0/3
description connected to PC 1
switchport access vlan 10
interface FastEthernet0/4
description connected to PC 2
switchport access vlan 20
interface Vlan2
description connected to ASA1
ip address 10.0.0.1  255.255.255.252
interface Vlan3
description Connected to ASA 2
ip address 10.0.1.1  255.255.255.252
interface Vlan10
description connected to PCs
ip address 192.168.10.1 255.255.255.0
interface Vlan20
ip address 192.168.20.1 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.0.0.2
ip route 0.0.0.0 0.0.0.0 10.0.1.2 2
Deepak Kumar
www.deepuverma.in
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
Hi Deepak, thank you for your answer.
I have one more question. Sorry for the ignorance, but I don´t know what configuration I have to do in the ASA, can you help me with commands?
Thank you a lot Deepak.
mvsheik123
Level 7
Level 7
You can use PBR (Policy based routing on switch) to control the path. Google for PBR examples.
hth
MS
Deepak Kumar
Your welcome, Here I am going to make ASA1 configuration :
interface Ethernet0/0
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
interface Vlan1
nameif inside
security-level 0
ip address 200.150.75.2 255.255.255.252
interface Vlan2
nameif outside
security-level 100
ip address 10.0.0.2 255.255.255.252
object network ASA-SW0
subnet 10.0.0.0 255.255.255.252
object network VLAN10
subnet 192.168.10.0 255.255.255.0
object network VLAN20
subnet 192.168.20.0 255.255.255.0
route outside 0.0.0.0 0.0.0.0 200.150.75.1 1
route inside 192.168.10.0 255.255.255.0 10.0.0.1 1
access-list LAN extended permit tcp any any
access-list LAN extended permit udp any any
access-list LAN extended permit icmp any any
access-group LAN in interface inside
nat (inside,outside) dynamic interface
If you are on real ASA then please replace NAT rules as below:
nat (inside,outside) after-auto source dynamic any interface
Please vote to correct answer.
Deepak Kumar
www.deepuverma.in
Deepak Kumar,
