how to find on which switch port an IP address is accessible?
Majid Jalinousi
There were tow 6513 switches that were VSSed.
I did "sh IP cef 172.20.3.15" on these VSSed switches and I saw:
172.20.3.0/24
  nexthop 172.22.194.57 Vlan699
Then I did "sh int vlan699" and I saw IP address for interface Vlan699 was 172.22.194.59 with mask 255.255.255.248.
After that I did "sh vlan id 699" and I saw vlan 699 was active on these interfaces: Te1/9/2, Te1/10/1, Te1/10/5, Te1/11/5, Te1/11/6, Te2/9/2, Te2/10/1,Te2/10/5, Te2/11/5, Te2/11/6, Po4, Po40, Po70, Po79, Po90, Po581, Po597
Then I did "sh ip arp 172.22.194.57" and I saw mac-address for this IP address was "4055.39dd.b900" and  then I searched this mac-address in mac-address-table and I saw this mac-address for vlan 699 has been learned through interface Po597.
When I did "ip int Po597" or "sh run int port-channel 597" surprisingly there was no such interface, but I could ping this IP address.
I want to know how this is possible? how is this IP address accessible?
Thanks in advance
Hey Morteza,
"The connection between the FWSM and the switch is a 6-GB 802.1Q trunking EtherChannel. This EtherChannel is automatically created when you install the FWSM. "
For more info see doc below.
https://www.cisco.com/c/en/us/td/docs/security/fwsm/fwsm32/configuration/guide/fwsm_cfg/switch_f.pdf
hope this helps
please rate helpful posts
thanks
10 Replies 10
Charles Hill
Do you see the port channel if you do a show etherchannel summary?
Thanks for your response
Yes I can see po597 when I do a sh etherchannel summary and members of this etherchannel are like below:
Gi2/5/1(P), Gi2/5/2(P), Gi2/5/3(P), Gi2/5/4(P), Gi2/5/5(P), Gi2/5/6(P)
But there are no such interfaces!
How is it possible?
Does show cdp neighbor g2/5/1
show anything?
No, there is nothing as output of that command,
I think there is no such interfaces, but output of command " sh run int gig 2/5/1" is like below"
"sh run interface gigabitEthernet 2/5/1
Building configuration...
Current configuration : 5 bytes
end"
what does it mean?
If you do a show module,
what is module 5?
Hi again
I did "sh module 5" and I saw like below:
Mod Ports              Card Type                       Model                     Serial No.
  5       6             Firewall Module            WS-SVC-FWM-1       SAL1526GX7V
How is it possible? Because I know this module hasn't any physical port.
Are they virtual ports? how can i find them in configuration script?
Hey Morteza,
hope this helps
thanks
Thanks for your help.
Your welcome
It could be the port channel that connects your wism to the infrastructure, if you have a wism.
if so, do a
show wism switch 1 module 5 controller 1 status
this will show the port channel on the wism.
hope this helps.
