NAT issues
Kaushik Ray
hello
I have a device connected to my Gi0/1 on my router with IP address as 192.168.1.2 255.255.255.0 and Gi0/1 is configured as 192.168.1.1 255.255.255.0
I have a loopback configured as a public ip address
I want that device with 192.168.1.2 to be able to be Natted to the Public IP address to be reached from another public ip address.
Gi0/2.374 is WAN side interface
So i configured as follows:
int gi0/1
ip nat inside
int GigabitEthernet0/2.374
ip nat outside
ip access-group nat.acl out
int lo374
ip adddress XXX.XXX.XXX.XXX 255.255.255.255
ip nat inside source list nat.acl interface lo374 overload
ip access-list extended nat.acl
 permit ip host XXX.XXX.XXX.XXX host YYY.YYY.YYY.YYY
 permit ip hostYYY.YYY.YYY.YYY host XXX.XXX.XXX.XXX
but when i am doing a show ip nat translations i am not seeing anything.
Any advise will be much appreciated on where i am going wrong.
Jon Marshall
You can't use the same acl for both NAT and to control traffic on your outside interface because the NAT acl needs to reference the private IP address of the host whereas the acl applied to the interface needs to reference the public IP.
So create a new acl for NAT and modify your NAT statement to use the new acl.
Jon
Jon Marshall
Jon
