PPTP VPN to Pass NAT on Cisco 2921 Router
soni.sunil
I am struggling to have my PPTP traffic to get routed through NAT to reach other Server LAN segment. I am using Cisco 2921 router as a PPTP server.
This Cisco 2921 router is working as PPTP server and doing NAT also to reach Server LAN segment (LAN-B).
My problem is after PPTP connection establishes I cannot reach any of the LAN segment, but after connecting PPTP I can browse Internet without any issue, but none of the LAN element is reachable. Please have a look on the configuration I am posting 2921 router configuration to suggest something, I have also attached the network setup for better understanding…Just to update Clients in LAN-A can access Internet as well as servers (LAN-B).
aaa new-model
aaa authentication ppp default local
aaa session-id common
clock timezone GMT 4 0
no ipv6 cef
no ip source-route
ip cef
ip multicast-routing
ip dhcp excluded-address 10.10.10.1 10.10.10.20
ip dhcp excluded-address 60.60.30.25 60.60.30.27
ip dhcp pool PUBLIC
network 60.60.30.24 255.255.255.248
dns-server 212.22.20.20 200.29.21.222
default-router 60.60.30.25
ip dhcp pool PRIVATE
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
ip domain name a.b.c
vpdn enable
vpdn-group PPTPVPN
! Default PPTP VPDN group
accept-dialin
protocol pptp
virtual-template 4
l2tp tunnel timeout no-session 15
username <> privilege 15 password 7 <>
ip tcp selective-ack
ip tcp path-mtu-discovery
ip ssh time-out 60
ip ssh authentication-retries 2
interface GigabitEthernet0/0
description ***Connected to Internet WAN Link***
ip address 80.80.80.78 255.255.255.252
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip flow egress
ip nat outside
ip virtual-reassembly in
load-interval 30
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
description ***Connected to LAN-A Hosts***
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip route-cache cef
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/1.10
description ***Connected to LAN-A Hosts Providing Internet Without NAT***
encapsulation dot1Q 10
ip address 60.60.30.25 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
interface GigabitEthernet0/1.20
description ***Connected to LAN-A Hosts Providing Internet Using NAT ***
encapsulation dot1Q 20
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
no cdp enable
interface GigabitEthernet0/2
description ***Connected to LAN-B Hosts***
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
load-interval 30
duplex auto
speed auto
interface GigabitEthernet0/2.100
description ***Connected to LAN-B for Management of Servers***
encapsulation dot1Q 100
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
no cdp enable
interface Virtual-Template4
ip unnumbered GigabitEthernet0/1.10
peer default ip address pool PPTP-POOL
ppp authentication ms-chap ms-chap-v2
ip local pool PPTP-POOL 60.60.30.27 60.60.30.28
ip forward-protocol nd
no ip http server
ip http secure-server
ip nat inside source route-map NAT_TO_MGMT interface GigabitEthernet0/2.100 overload
ip nat inside source route-map NAT_TO_INTERNET interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 80.80.80.77
ip route 10.20.20.0 255.255.252.0 GigabitEthernet0/2.100 192.168.1.2
ip access-list extended VTY_Access
permit tcp 10.10.10.0 0.0.0.255 any eq telnet
permit tcp 10.10.10.0 0.0.0.255 any eq 22
permit tcp 60.60.30.24 0.0.0.7 any eq telnet
permit tcp 60.60.30.24 0.0.0.7 any eq 22
deny   tcp any any
access-list 10 permit 10.10.10.0 0.0.0.255
access-list 10 permit 172.21.21.0 0.0.0.7
access-list 20 permit 10.10.10.0 0.0.0.255
access-list 20 permit 60.60.30.24 0.0.0.7
access-list 20 permit 172.21.21.0 0.0.0.7
route-map NAT_TO_MGMT permit 10
match ip address 10
match interface GigabitEthernet0/2.100
route-map NAT_TO_INTERNET permit 10
match ip address 20
match interface GigabitEthernet0/0
line vty 0 4
access-class VTY_Access in
transport preferred ssh
transport input telnet ssh
transport output all
end
0 Replies 0
