How to find VPN tunnel BW
asoka
My router is 2851 and running :c2800nm-adventerprisek9-mz.124-24.T2.bin
And I have 13 differenet IPSec vpn tunnels to other locations
How can I find the each VPN tunnel bandwidth
I explore teh NBAR method, aand its dont recognise IPSEC traffic
And,
sh crypto engine accelerator statistic
command give yo last 5 minutes bits/sec in and out capacitry but it is the total.
I thought I can go to other end, which is 1760 routers and they dont give you 5 mts tarffic in and out info like 2851
Regarsd
Giuseppe Larosa
Hello Asoka,
I would use
ip accounting output-packets
on physical interface of HQ router
you should be able with
sh ip accounting
to see the flows of IPSec you know the endpoints IP addresses
or an ACL with log option with one line with log option for each IPSec tunnel
Hope to help
Giuseppe
