How to get DHCP from a firewall to a Cisco 1000 48p
lk052
I cannot get the firewall to provide dhcp after trying several options. I tried using it as the ip router, the default gateway with no success unfortunately. I would prefer getting it from the DC but management wants it strictly from the firewall.
5 Replies 5
M02@rt37
Hello @lk052
which Firewall is it ?
Best regards
Barracuda Cloudgen F380b
the FW must be GW of client otherwise it can not assign IP to client.
When I make the firewall the GW the switch will not work. It cannot be logged into by putty/GUI
OK, keep the GW in SW and only config IP helper under the SVI of client VLAN  toward the FW for DHCP.
