How to get line protocol up/down notification at SP level?
mtsb
Hi all,
In some box I see "%LINEPROTO-5-UPDOWN" message at RP and in some box I see "%LINEPROTO-SP-5-UPDOWN" SP message as well. How to enable  this logging status @ at SP level?
Madhu
vmiller
Level 7
Level 7
need to set the logging level for syslog.
http://www.techrepublic.com/article/get-to-know-your-logging-options-in-the-cisco-ios/6084442
should help for starters
Thanks for the response. I have already set the logging levels but in some box I see logg events being recorded from SP (switch processor) and in some box I get from route processor (RP). I just want to know if I need to set something to get logging events from SP? I am talking about 7600 router model.
Madhu
If you already configured syslgo on this units you can add the command bellow on the interface config menu
interface GigabitEthernetx/x
logging event link-status
Good luck
Gonçalo
