How to get RTSP through NAT
computerone1
Whatever I try, I can't manage to have RTSP (Real-Time Streaming Protocol) pass through a Cisco881K9 running NAT:
The TCP flux is running OK, but the UDP AV flux gets stopped by the NAT.
The client is lan-side, the server is wan-side.
The C881K9 is performing InterVlanRouting, with a trunk on one of its switching module.
Nat is running, and there are a few ACLs to isolate the vlans.
It's a very simple configuration.
Everything is working perfectly, except the RTSP audio/video streams.
Doesn anybody know how to manage this problem?
Here are the hardware/software/license versions:
Cisco IOS Software, C880 Software (C880DATA-UNIVERSALK9-M), Version 15.4(3)M9, RELEASE SOFTWARE (fc1)
License Level: advipservices   Type: Permanent
Here is the C881K9 basic config (stripped-down and anonymized):
ip domain name example.com
ip name-server 208.67.220.220
ip name-server 208.67.222.222
ip multicast-routing
ip cef
interface FastEthernet0
 no ip address
interface FastEthernet1
 no ip address
interface FastEthernet2
 no ip address
interface FastEthernet3
 switchport trunk native vlan 110
 switchport mode trunk
 no ip address
interface FastEthernet4
 description WAN
 ip address 172.16.7.240 255.255.255.0
 ip nat outside
 ip virtual-reassembly in
 duplex auto
 speed auto
interface Vlan1
 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
 no ip address
 ip tcp adjust-mss 1452
interface Vlan10
 ip address 172.16.10.1 255.255.255.0
 ip access-group ACL1 in
 ip nat inside
interface Vlan20
 ip address 172.16.20.1 255.255.255.0
 ip nat inside
interface Vlan30
 ip address 172.16.30.1 255.255.255.0
 ip nat inside
interface Vlan40
 ip address 172.16.40.1 255.255.255.0
 ip nat inside
interface Vlan100
 ip address 172.16.100.1 255.255.255.0
 ip nat inside
ip forward-protocol nd
ip nat inside source list 100 interface FastEthernet4 overload
ip route 0.0.0.0 0.0.0.0 172.16.7.1
ip access-list extended ACL1
 permit ip 172.16.10.0 0.0.0.255 172.16.10.0 0.0.0.255
 permit ip 172.16.20.0 0.0.0.255 172.16.20.0 0.0.0.255
 permit ip 172.16.30.0 0.0.0.255 172.16.30.0 0.0.0.255
 permit ip 172.16.40.0 0.0.0.255 172.16.40.0 0.0.0.255
 permit ip 172.16.100.0 0.0.0.255 172.16.100.0 0.0.0.255
 permit ip 172.16.10.0 0.0.0.255 172.16.40.0 0.0.0.255
 permit ip 172.16.40.0 0.0.0.255 172.16.10.0 0.0.0.255
 deny   ip 172.16.0.0 0.0.255.255 172.16.0.0 0.0.255.255 log-input
 permit ip any any
access-list 100 permit ip 172.16.0.0 0.0.255.255 any
control-plane
 vstack
I think you have to enable NAT traversal. Check the doc below (it works in conjunction with pools):
https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr_nat/configuration/12-4t/nat-12-4t-book/iadnat-host-sbc.html
javierzuleta
tenia el mismo problema. resulta que NAT overload no acepta a RTSP.
RTSP solo es posible con NAT estático.
anchambe
I wanted to post this here since I came across this thread when searching for the problem too. This is a known bug on the IOS platform with RTSP and NAT ALG. Here is the link to the bug:
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCtn86205
The feature works on IOS XE, but not IOS.
