How to get the AUSM firmware information with the serial number
ronald-salas
I need to get a way to get the firmware information of an AUSM card with the card?s serial number. The problem is that the MGX 8850 doesn?t recognize the card, so i need to find this information in another way!!
thomas.chen
Level 6
Level 6
Use the dspcd command to view hardware and firmware information about the selected PXM.
http://www.cisco.com/univercd/cc/td/doc/product/wanbu/bpx8600/pnni_ses/rel1_0/softw/orcgapb2.pdf
switchxchange
Hi Ronald -
the AUSM is passive in that the firmware is automatically downloaded from the PXM card.
Just issue the "dspfwrevs" command on the active PXM and it will show you which firmware versions are installed in the "C:FW" directory.
rgds
Joern Pasche
SwitchXchange, Inc.
jpasche@switchxchange.com
