Pls give solution
iqbalkhan
I have two ACS unix 2.3.6.Both are UP & running.One is configured with at least 150 user profiles and other one have 10 user profiles.Is it possible to backup database from 1st one and load it to 2nd one so that they are identical without configuring(user profiles) 2nd one manually? They are pingable.
Biplob
purohit_810
Level 5
Level 5
Yes, You can take backup configurration for User Database as well as Configuration of ACS.
Go Into System Configuration -- > You will see ACS back up. and restore.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080742f60.shtml
Dharmesh Purohit
To much Thanks. I am using ACS (UNIX) version 3.0. so it is possible in 3.0 version ?. becuse I found your example is 4.0.
Biplob
