How to identify which gateway is forwarding packets
abhdivak
Hello all,
Assume that one site have two gateways. And my question is how to identify which gateway is currently forwarding and receiving the packets ?
Abhijith
Nagendra Kumar Nainar
Hi Abhijit,
It depends on how your network is designed. How is your network designed?. Both the GW are connected to same LAN with FHRP (like HSRP, VRRP etc) enabled?.
