How to increase HWIC density in 3845
ashley_dew
I have got 3845/3945, I would like to increase HWIC slot density for HWIC 4 PORT ISDN BRI S/T ports through the NM/NME/NMX slots, Is there any measns to do that?
Ashley
kmothukuri
Hi ,
Note 1 - Please refer to the Cisco Supported and Unsupported Modules for Integrated Services Routers document for specific information regarding modules and quantities supported on a given platform.
New Modules390029001900
EHWIC-1GE-SFP-CU
EHWIC 1 port dual mode SFP(100M/1G) or GE(10M/100M/1G)
Data Sheet   Q&A
EHWIC-3G-HSPA-U
3.5G EHWIC (Non-US) HSPA/UMTS 850/900/1900/2100MHz SMS/GPS
Data Sheet
EHWIC-3G-EVDO-V
3G EHWIC Verizon EV-DO Rev A/0/1xRTT 800/1900MHz with SMS/GPS
Data Sheet
EHWIC-3G-EVDO-S
3G EHWIC Sprint EV-DO Rev A/0/1xRTT 800/1900MHz with SMS/GPS
Data Sheet
EHWIC-3G-EVDO-B
3G EHWIC BSNL EV-DO Rev A/0/1xRTT 800/1900MHz with SMS/GPS
Data Sheet
EHWIC-VA-DSL-A
Multi Mode VDSL2/ADSL/2/2+ EHWIC Annex A
Data Sheet   Q&A
EHWIC-VA-DSL-B
Multi Mode VDSL2/ADSL/2/2+ EHWIC Annex B
Data Sheet   Q&A
EHWIC-VA-DSL-M
Multi Mode VDSL2/ADSL/2/2+ EHWIC Annex M
Data Sheet   Q&A
HWIC-3G-CDMA-T
3G (for India only) HWIC TATA EVDO Rev A/0/1xRTT 800/1900MHz
Data Sheet   Q&A   More Information
HWIC-1VDSL
1-port VDSL HWIC with support for VDSL2 over basic telephone service
Data Sheet    Q&A
SM-SRE-910-K9
Services Ready Engine (SRE) Service Module, 4 GB of DRAM, x2 512-GB Hard Drive, 2-GB USB Flash
SM-SRE-900-K9
SM-SRE-710-K9
Services Ready Engine (SRE) Service Module, 2 GB of DRAM, 512-GB Hard Drive, 512-MB USB Flash
SM-SRE-700-K9
ISM-SRE-300-K9
Services Ready Engine (SRE) Internal Service Module, 512 MB of DRAM, 4-GB USB Flash
Data Sheet    Q&A   More Information   Note: Not available for the Cisco 1941W, 3925E, and 3945E
Application390029001900
SM-SRE-910-K9
SM-SRE-900-K9
SM-SRE-710-K9
SM-SRE-700-K9
ISM-SRE-300-K9
NME-APPRE-522-K9
Application Runtime Engine (2 GB RAM 160 GB HDD)
Data Sheet    Q&A    More Information Note: Available on the Cisco 2951-3945E only
NME-APPRE-502-K9
Application Runtime Engine (1 GB RAM 120 GB HDD)
NME-APPRE-302-K9
Application Runtime Engine (512 MB RAM 80 GB HDD)
NME-WAE-502-K9
Cisco Wide Area Application Services (WAAS) Network Module – 1 GB RAM, 120 GB HDD
Data Sheet  Note: Not available for the Cisco 3925E, and 3945E
EVM-IPVS-16A
16-port Analog Video Gateway
NME-NAM-120S
Cisco Branch Routers Series Network Analysis Network Module 120 GB (SATA)
NME-NAM-80S
Cisco Branch Routers Series Network Analysis Network Module 80GB (SATA)
VPN and Security390029001900
NME-NAC-K9
Cisco NAC Network Module for 2800 and 3800 ISR
NME-IPS-K9
Cisco IPS NM for 2811, 2821, 2851 and 3800
Data Sheet   More Information
Ethernet Switch390029001900
SM-D-ES3G-48-P
Enhanced EtherSwitch, L2/L3, Double-Wide Service Module, 48 Gb Ethernet, 2 Small Form-Factor Pluggable (SFP) ports, Power over Ethernet (PoE)
Data Sheet    Q&A
SM-D-ES3-48-P
Enhanced EtherSwitch, L2/L3, Double-Wide Service Module, 48 Fast Ethernet, 2 SFP, PoE
Data Sheet    Q&A
SM-ES3G-24-P
Enhanced EtherSwitch, L2/L3, Service Module, 24 Gb Ethernet, PoE
Data Sheet    Q&A
SM-ES3-24-P
Enhanced EtherSwitch, L2/L3, Service Module, 23 Fast Ethernet, 1 Gb Ethernet, PoE
Data Sheet    Q&A
SM-ES3G-16-P
Enhaced EtherSwitch, L2/L3, Service Module, 16 Gb Ethernet, PoE
Data Sheet    Q&A
SM-ES3-16-P
Enhanced EtherSwitch, L2/L3, SM, 15 Fast Ethernet, 1 Gb Ethernet, PoE
Data Sheet    Q&A
SM-D-ES2-48
Enhanced EtherSwitch, L2, Double Wide Service Module, 48 Fast Ethernet, 2 SFP
Data Sheet    Q&A
SM-ES2-24-P
Enhanced EtherSwitch, L2, Service Module, 23 Fast Ethernet, 1 Gb Ethernet, PoE
Data Sheet    Q&A
SM-ES2-24
Enhanced EtherSwitch, L2, Service Module, 23 Fast Ethernet, 1Gb Ethernet
Data Sheet    Q&A
SM-ES2-16-P
Enhanced EtherSwitch, L2, Service Module, 15 Fast Ethernet, 1 Gb Ethernet, PoE
Data Sheet    Q&A
NME-16ES-1G-P
One 16-port 10/100 Cisco EtherSwitch service module with 802.3af, 1 10/100/1000 port, and IP Base
NME-16ES-1G
One 16-port 10/100 EtherSwitch service module, 1 10/100/1000 port, and IP Base
EHWIC-D-8ESG-P
8-port double-wide Gb Ethernet switch EHWIC, PoE capable
Data Sheet   Q&A
EHWIC-D-8ESG
Data Sheet   Q&A
EHWIC-4ESG-P
4-port single-wide Gb Ethernet switch EHWIC, PoE capable
Data Sheet   Q&A
EHWIC-4ESG
Data Sheet   Q&A
HWIC-D-9ESW-POE
9-port Ethernet switch HWIC, PoE capable
Data Sheet   Q&A   Note: Not supported on the Cisco 1941W
HWIC-4ESW-POE
4-port Ethernet switch HWIC, PoE capable
HWIC-D-9ESW
9-port double-wide 10/100BaseT Ethernet switch HWIC
HWIC-4ESW
4-port single-wide 10/100BaseT Ethernet switch HWIC
NM-16ESW-1GIG
16-port 10/100 Cisco EtherSwitch Network Module with 1 Gb Ethernet (1000BASE-T) port
Data Sheet   More Information  Note: Not supported on the 3925E or 3945E
NM-16ESW
Ethernet Routed-Port390029001900
EHWIC-1GE-SFP-CU
Data Sheet   Q&A
HWIC-1GE-SFP
1-SFP slot Gb Ethernet HWIC
Data Sheet   Q&A
HWIC-2FE
2-port 10/100 Routed-Port HWIC
Data Sheet   Q&A
HWIC-1FE
1-port 10/100 Routed-Port HWIC
Data Sheet  Q&A
Wireless LAN and WAN390029001900
NME-AIR-WLC25-K9
25-AP WLAN Controller NM
NME-AIR-WLC12-K9
12-AP WLAN Controller NM
NME-AIR-WLC6-K9
6-AP WLAN Controller NM
EHWIC-4G-LTE-V (Available Q3CY2011)
Dedicated 4G LTE EHWIC for Verizon Wireless Network, US (Verizon SKU) operates on LTE at 700MHz (band 13) with GPS
Q&A
EHWIC-3G-HSPA-U
3.5G EHWIC (Non-US) HSPA/UMTS 850/900/1900/2100MHz with SMS/GPS
Data Sheet
EHWIC-3G-EVDO-V
Data Sheet
EHWIC-3G-EVDO-S
Data Sheet
EHWIC-3G-EVDO-B
Data Sheet
HWIC-3G-HSPA-G
3.5G HWIC (Non-US) HSPA/UMTS 900/1900/2100MHz; Quad-band 2G
HWIC-3G-HSPA
3.5G WWAN HWIC-HSPA/UMTS/EDGE/GPRS
HWIC-3G-HSPA-A
3.5G HWIC ATT HSPA/UMTS 850/1900/2100MHz; Quad-band 2G
HWIC-3G-CDMA-V
3G HWIC Verizon EV-DO Rev A/0/1xRTT 800/1900MHz
HWIC-3G-CDMA-S
3G HWIC Sprint EV-DO Rev A/0/1xRTT 800/1900MHz
HWIC-3G-CDMA-B
3G (for India only) HWIC BSNL EVDO Rev A/0/1xRTT 800/1900MHz
HWIC-3G-CDMA-T
Voice Modules
Cisco Unified SIP Proxy390029001900
NME-CUSP-522
Data Sheet       Note: Available on the Cisco 2951-3945E only    End of Sale Notice
Analog and Digital Voice/Fax390029001900
NM-HDV2-2T1/E1
IP Communications High-Density Digital Voice NM with 2 T1/E1
Data Sheet
NM-HDV2-1T1/E1
Data Sheet
NM-HDV2
Data Sheet
NM-HD-2VE
2-slot IP Communications Enhanced Voice/Fax Network Module
Data Sheet
NM-HD-2V
2-slot IP Communications Voice/Fax Network Module
Data Sheet
NM-HD-1V
1-slot IP Communications Voice/Fax Network Module
Data Sheet
EM-HDA-3FXS/4FXO
A 7-port expansion module with 3 FXS and 4 FXO ports
Data Sheet
EM-HDA-6FXO
Six-port FXO voice/fax expansion module
Data Sheet
EVM-HD-8FXS/DID
High-density voice/fax extension module – 8 FXS/DID
Data Sheet   Q&A
T1, E1, and G.703 Multiflex Trunk Voice and WAN Interface Cards390029001900
VWIC3-4MFT-T1/E1
4-port T1/E1 Voice / WAN w/ Drop & Insert
Data Sheet
VWIC3-2MFT-T1/E1
2-port T1/E1 Voice / WAN w/ Drop & Insert
Data Sheet
VWIC3-1MFT-T1/E1
1-port T1/E1 Voice / WAN w/ Drop & Insert
Data Sheet
VWIC3-2MFT-G703
2-port T1/E1 Voice / WAN w/ D&I & unstructured E1 (G703)
Data Sheet
VWIC3-1MFT-G703
1-port T1/E1 Voice / WAN w/ D&I & unstructured E1 (G703)
Data Sheet
VWIC2-2MFT-T1/E1
Data Sheet
VWIC2-1MFT-T1/E1
Data Sheet
VWIC2-2MFT-G703
Data Sheet
VWIC2-1MFT-G703
Data Sheet
Voice Interface Cards390029001900
EVM-HD-8FXS/DID
Data Sheet
EM-4BRI-NT/TE
4-port voice/fax expansion module BRI
Data Sheet
VIC2-2BRI-NT/TE
2-port VIC-BRI (NT and TE)
Data Sheet
VIC3-4FXS/DID
4-port FXS and DID voice/fax interface card
Data Sheet
VIC3-2FXS/DID
2-port FXS and DID voice/fax interface card
Data Sheet
VIC3-2FXS-E/DID
2-port FXS enhanced and DID voice/fax interface card
Data Sheet
VIC3-2E/M
2 port E&M voice/fax interface card
Data Sheet
VIC2-4FXO
4-port VIC-FXO (universal)
Data Sheet
VIC2-2FXO
2-port VIC-FXO (universal)
Data Sheet
Cisco Unity Voicemail390029001900
NME-CUE
Cisco Unity Express Network Module Enhanced (8 ports included)
Data Sheet   Q&A    End of Sale Notice
NME-UMG-EC
Cisco Unified Messaging Gateway - Enhanced Capacity
Data Sheet  Q&A   More Information    End of Sale Notice
NME-UMG
Packet Voice and Video Digital Signal Processor Modules 3390029001900
PVDM3-256
256-channel voice and video DSP module
Data Sheet   Q&A
PVDM3-192
192-channel voice and video DSP module
Data Sheet   Q&A
PVDM3-128
128-channel voice and video DSP module
Data Sheet   Q&A
PVDM3-64
64-channel voice and video DSP module
Data Sheet   Q&A
PVDM3-32
32-channel voice and video DSP module
Data Sheet   Q&A
PVDM3-16
16-channel voice and video DSP module
Data Sheethttp://www.cisco.com/en/US/customer/prod/collateral/modules/ps3115/ps6024/prod_qas0900aecd8016c6ad_ps3115_Products_Q_and_A_Item.html   Q&A
Packet Voice Digital Signal Processor Modules 2390029001900
PVDM2-64
64-channel fax and voice DSP module
Data Sheet  Q&A
PVDM2-48
48-channel fax and voice DSP module
Data Sheet  Q&A
PVDM2-32
32-channel fax and voice DSP module
Data Sheet  Q&A
PVDM2-16
16-channel fax and voice DSP module
Data Sheet  Q&A
PVDM2-8
Data Sheet  Q&A
Broadband390029001900
EHWIC-VA-DSL-A
Data Sheet  Q&A
EHWIC-VA-DSL-B
Data Sheet  Q&A
EHWIC-VA-DSL-M
Data Sheet  Q&A
HWIC-CABLE-D-2
1-port DOCSIS 2.0 qualified cable modem HWIC
HWIC-CABLE-E/J-2
1-port Euro/J-DOCSIS 2.0 qualified cable modem HWIC
HWIC-4SHDSL-E
4-pair G.SHDSL HWIC with 2-wire, 4-wire, and 8-wire support
Data Sheet  Q&A
HWIC-4SHDSL
Data Sheet  Q&A
HWIC-2SHDSL
2-pair G.SHDSL HWIC with 2-wire and 4-wire support
Data Sheet  Q&A
HWIC-ADSL-B/ST
2-port HWIC with 1-port ADSL over basic telephone service and 1-port ISDN BRI-S/T
Data Sheet
HWIC-ADSLI-B/ST
2-port HWIC with 1-port ADSL over ISDN and 1-port ISDN BRI-S/T
Data Sheet
HWIC-1ADSL
1-port ADSL over basic telephone service HWIC
Data Sheet  Note: Not available for the Cisco 3925E and 3945E
HWIC-1ADSLI
1-port ADSL over ISDN HWIC
HWIC-1ADSL-M
1-port ADSL over basic telephone service HWIC (Annex M)
Data Sheet
HWIC-1VDSL
Data Sheet  Q & A
Serial WAN Interface390029001900
HWIC-1DSU-56K4
1-Port 4-Wire 56/64 Kpbs CSU/DSU WAN Interface Card
Datasheet
NM-1T3/E3
1-port clear-channel T3/E3 network module
Data Sheet Note: Supported on the Cisco 2951-3945E
HWIC-4T1/E1
4-port clear-channel T1/E1 HWIC
Data Sheet
HWIC-4T
4-port serial HWIC
Data Sheet  Q&A
HWIC-1DSU-T1
1-Port T1/Fractional T1 DSU/CSU High-Speed WAN Interface Card
Data Sheet    Q&A
HWIC-1T
1-Port Serial High-Speed WAN Interface Card
Data Sheet    Q&A
HWIC-2T
2-Port Serial High-Speed WAN Interface Card
Data Sheet    Q&A
Channelized T1/E1 and ISDN PRI390029001900
NM-8CE1T1-PRI
1-port Channelized E1/T1/ISDN PRI High-Speed WAN Interface Card (HWIC)
Data Sheet
HWIC-2CE1T1-PRI
2-port Channelized E1/T1/ISDN PRI HWIC
Data Sheet
HWIC-1CE1T1-PRI
1-port Channelized E1/T1/ISDN PRI HWIC
Data Sheet
ISDN BRI390029001900
VIC2-2BRI-NT/TE
2-port VIC card-BRI (NT and TE)
Data Sheet
HWIC-4B-S/T
4-port ISDN BRI High-Speed WAN Interface Card
Data Sheet
HWIC-1B-U
1-port ISDN BRI U High-Speed WAN Interface Card
Data Sheet
WIC-1B-S/T-V3
1-port ISDN WAN Interface Card (dial and leased line)
ATM390029001900
NM-1A-OC3-POM
1-port ATM OC-3 module with single pluggable optical module (Small Form-Factor Pluggable) slot
Data Sheet
NM-1A-T3/E3
1-port T3/E3 ATM network Module
Data Sheet
Sync/Async390029001900
HWIC-16A
16-port Async HWIC
Data Sheet  Q&A
HWIC-8A
8-port Async HWIC
Data Sheet  Q&A
SM-32A
χ
χ
32-port Async Service Module
Data Sheet  Q&A
HWIC-8A/S-232
8-port Async/Sync Serial HWIC, EIA-232
Data Sheet   Q&A
HWIC-4A/S
4-port Async/Sync Serial HWIC
Data Sheet   Q&A
HWIC-2A/S
2-Port Async/Sync Serial High-Speed WAN Interface Card
Data Sheet   Q&A
Analog Dialup and Remote Access390029001900
WIC-2AM-V2
2-port analog modem WIC
Data Sheet
WIC-1AM-V2
1-port analog modem WIC
Data Sheet
Digital Modem390029001900
PVDM2-36DM
36-port digital modem module
Data Sheet  Q&A  Note: Not available for the Cisco 3925E and 3945E    End of Sale Notice
PVDM2-24DM
24-port digital modem module
PVDM2-12DM
12-port digital modem module
USB Flash Storage390029001900
MEMUSB-1024FT
1-GB USB Flash Token
Small Form-Factor Pluggable390029001900
ISR G2 on-board Gb Ethernet
SM-D-ES3G-48-P
SM-D-ES3-48-P
SM-D-ES3 Data Sheet
SM-D-ES2-48
SM-D-ES2-48 Data Sheet
HWIC-1GE-SFP
HWIC-1GE-SFP Data Sheet
kmothukuri
New Modules
HWIC-3G-HSPA
HWIC-3G-HSPA-A
HWIC-3G-HSPA-G
3GWWAN HWIC GPRS/EDGE/UMTS/HSPA
Data Sheet    Q&A
Application Modules
NME-APPRE-522-K9Application Runtime Engine (2 GB RAM 160 GB HDD)
NME-APPRE-502-K9Application Runtime Engine (1 GB RAM 120 GB HDD)
NME-APPRE-302-K9Application Runtime Engine (512 MB RAM 80 GB HDD)
NME-WAE-522-K9Cisco WAAS Network Module, 1 GB RAM, 160 GB HDD (WAAS Transport and WAAS Enterprise supported)
Data Sheet
NME-WAE-502-K9Cisco Wide Area Application Services (WAAS) Network Module – 1 GB RAM, 120 GB HDD
Data Sheet
NME-WAE-302-K9Cisco Wide Area Application Services (WAAS) Network Module – 512 MB RAM, 80 GB HDD (only transport supported)
Data Sheet
EVM-IPVS-16A16-port Analog Video Gateway
NME-VMSS-HP32Cisco Video Management and Storage System HP NME 32 ports
Data Sheet   Q&A   More Information   End-of-Sale Notice
NME-VMSS-HP16Cisco Video Management and Storage System HP NME 16 ports
NME-NAM-120SCisco Branch Routers Series Network Analysis Network Module 120 GB (SATA)
VPN and Security Modules
NME-NAC-K9Cisco NAC Network Module for 2800 and 3800 ISR
NME-IPS-K9Cisco IPS NM for 2811, 2821, 2851 and 3800
AIM-IPS-K9Cisco IPS AIM for 1841, 2800, and 3800 ISR
AIM-VPN/SSL-3DES/3DES/AES/SSL VPN Encryption/Compression AIM Module
Data Sheet   Q&A
Ethernet Switch Modules
NME-XD-48ES-2S-POne 48-port 10/100 Cisco EtherSwitch service module with 802.3af, 2 SFPs, and IP Base
NME-X-23ES-1G-POne 23-port 10/100 Cisco EtherSwitch service module with 802.3af, 1 10/100/1000 port with 802.3af, and IP Base
NME-X-23ES-1GOne 23-port 10/100 EtherSwitch service module, 1 10/100/1000 port, and IP Base
NME-16ES-1G-POne 16-port 10/100 Cisco EtherSwitch service module with 802.3af, 1 10/100/1000 port, and IP Base
NME-16ES-1GOne 16-port 10/100 EtherSwitch service module, 1 10/100/1000 port, and IP Base
HWIC-D-9ESW-POE9-port Ethernet switch HWIC, Power over Ethernet capable
Data Sheet   Q&A
HWIC-4ESW-POE4-port Ethernet switch HWIC, Power over Ethernet capable
Data Sheet   Q&A
HWIC-D-9ESW9-port double-wide 10/100BaseT Ethernet switch HWIC
Data Sheet   Q&A
HWIC-4ESW4-port single-wide 10/100BaseT Ethernet switch HWIC
Data Sheet   Q&A
NM-16ESW-1GIG16-port 10/100 Cisco EtherSwitch Network Module with 1 Gigabit Ethernet (1000BASE-T) port
Data Sheet   More Information   End-of-Sale Notice
NM-16ESW16-port 10/100 Cisco EtherSwitch Network Module
Ethernet Routed-Port Modules
HWIC-1GE-SFP1-SFP slot Gb Ethernet HWIC
Data Sheet   Q&A
HWIC-2FE2-port 10/100 Routed-Port HWIC
Data Sheet   Q&A
HWIC-1FE1-port 10/100 Routed-Port HWIC
Data Sheet  Q&A
NM-2FE2W-V22-port 10/100 Ethernet 12=WIC-slot network module, version 2
Data Sheet   End-of-Sale Notice
NM-1FE2W-V21-port 10/100 Ethernet 12=WIC-slot network module, version 2
NM-1FE1R2W1-port 10/100 Ethernet 1-port 4/16 Token Ring 2-WIC-slot-network module
NM-2W2-WIC-slot network module (no LAN )
Data Sheet
Wireless LAN and WAN Modules
NM-1VSAT-GILATCisco IP VSAT Satellite WAN Network Module
NME-AIR-WLC25-K925-AP WLAN Controller NM for Cisco 2800/3800 Series
NME-AIR-WLC12-K912-AP WLAN Controller NM for Cisco 2800/3800 Series
NME-AIR-WLC8-K98-AP WLAN Controller NM for Cisco 2800/3800 Series
NME-AIR-WLC6-K96-AP WLAN Controller NM for Cisco 2800/3800 Series
HWIC-AP-AG-B
HWIC-AP-AG-P
HWIC-AP-AG-N
802.11a/b/g HWIC access point interface card (B-Americas; P-Japan; N-Australia/New Zealand)
Data Sheet
HWIC-AP-AG-E802.11a/b/g HWIC access point interface card (E-Europe)
HWIC-AP-G-A
HWIC-AP-G-E
HWIC-AP-G-J
802.11b/g HWIC access point interface card (A-Americas; E-Europe; J-Japan)
Data Sheet
HWIC-3G-CDMA
HWIC-3G-CDMA-V
HWIC-3G-CDMA-S
3G WWAN HWIC-EVDO Rev A/Rel 0/1xRTT-800/1900 MHz
HWIC-3G-HSPA3GWWAN HWIC GPRS/EDGE/UMTS/HSPA
Data Sheet    Q&A
Voice Modules
NME-CUSP-522Cisco Unified SIP Proxy
Data Sheet
Analog and Digital Voice/Fax Modules
NM-HDV2-2T1/E1IP Communications High-Density Digital Voice NM with 2 T1/E1
Data Sheet
NM-HDV2-1T1/E1IP Communications High-Density Digital Voice NM with 1 T1/E1
Data Sheet
NM-HDV2IP Communications High-Density Digital Voice Network Module
Data Sheet
NM-HD-2VE2-slot IP Communications Enhanced Voice/Fax Network Module
Data Sheet
NM-HD-2V2-slot IP Communications Voice/Fax Network Module
Data Sheet
NM-HD-1V1-slot IP Communications Voice/Fax Network Module
Data Sheet
EVM-HD-8FXS/DIDHigh density voice/fax extension module - 8 FXS/DID
Data Sheet   Q&A
EC-MFT-3232 Channel Echo Cancellation Module
Data Sheet
EC-MFT-6464 Channel Echo Cancellation Module
Data Sheet
VWIC2-2MFT-T1/E12-port T1/E1 Voice / WAN w/ Drop & Insert
Data Sheet
VWIC2-1MFT-T1/E11-port T1/E1 Voice / WAN w/ Drop & Insert
Data Sheet
VWIC2-2MFT-G7032-port T1/E1 Voice / WAN w/ D&I & unstructured E1 (G703)
Data Sheet
VWIC2-1MFT-G7031-port T1/E1 Voice / WAN w/ D&I & unstructured E1 (G703)
Data Sheet
EVM-HD-8FXS/DIDHigh-density voice/fax extension module - 8 FXS/DID
Data Sheet
EM3-HDA-8FXS/DIDHigh-density voice/fax extension module – 8 FXS/DID
Data Sheet
EM-HDA-3FXS/4FXOA 7-port expansion module with 3 FXS and 4 FXO ports
Data Sheet
EM-HDA-6FXOSix-port FXO voice/fax expansion module
Data Sheet
EM-4BRI-NT/TEFour-port BRI voice/fax expansion module
Data Sheet
VIC2-2BRI-NT/TE2-port VIC-BRI (NT and TE)
Data Sheet
VIC3-4FXS/DID4-port FXS and DID voice/fax interface card
Data Sheet
VIC3-2FXS/DID2-port FXS and DID voice/fax interface card
Data Sheet
VIC3-2FXS-E/DID2-port FXS enhanced and DID voice/fax interface card
Data Sheet
VIC3-2E/M2 port E&M voice/fax interface card
Data Sheet
VIC2-4FXO4-port VIC-FXO (universal)
Data Sheet
VIC2-2FXO2-port VIC-FXO (universal)
Data Sheet
NME-CUECisco Unity Express Network Module Enhanced (8 ports included)
Data Sheet   Q&A
AIM2-CUE-K9Cisco Unity Express Voice Mail AIM
Q&A
NME-UMG-ECCisco Unified Messaging Gateway - Enhanced Capacity
NME-UMGCisco Unified Messaging Gateway
PVDM2-6464-channel fax and voice DSP module
Data Sheet  Q&A
PVDM2-4848-channel fax and voice DSP module
Data Sheet  Q&A
PVDM2-3232-channel fax and voice DSP module
Data Sheet  Q&A
PVDM2-1616-channel fax and voice DSP module
Data Sheet  Q&A
PVDM2-88-channel fax and voice DSP module
Data Sheet  Q&A
Broadband Modules
HWIC-CABLE-D-21-port DOCSIS 2.0 qualified cable modem HWIC
Data Sheet  Q&A
HWIC-CABLE-E/J-21-port Euro/J-DOCSIS 2.0 qualified cable modem HWIC
Data Sheet  Q&A
HWIC-4SHDSL4-pair G.SHDSL HWIC with 2-wire, 4-wire, and 8-wire support
Data Sheet  Q&A
HWIC-2SHDSL2-pair G.SHDSL HWIC with 2-wire and 4-wire support
Data Sheet  Q&A
HWIC-ADSL-B/ST2-port HWIC with 1-port ADSLoPOTS and 1-port ISDN BRI-S/T
HWIC-ADSLI-B/ST2-port HWIC with 1-port ADSLoISDN and 1-port ISDN BRI-S/T
HWIC-1ADSL1-port ADSLoPOTS HWIC
HWIC-1ADSLI1-port ADSLoISDN HWIC
HWIC-1ADSL-M1-port ADSL over basic telephone service HWIC (Annex M)
WIC-1SHDSL-V31-port G.SHDSL WIC with 4-wire support
Data Sheet
Serial WAN Interface Modules
NM-1T3/E31-port clear-channel T3/E3 network module
Data Sheet
NM-4T4-port Sync Serial Network Module
Data Sheet
HWIC-4T1/E14-port clear-channel T1/E1 HWIC
Data Sheet
HWIC-4T4-port serial HWIC
Data Sheet  Q&A
HWIC-1DSU-T11-port T1/Fractional T1 DSU/CSU High-Speed WAN Interface Card
Data Sheet    Q&A
HWIC-1T1-port Serial High-Speed WAN Interface Card
Data Sheet    Q&A
HWIC-2T2-port Serial High-Speed WAN Interface Card
Data Sheet    Q&A
WIC-1DSU-56K41-port 4-wire 56-/64-kbps CSU/DSU WIC
Data Sheet
Channelized T1/E1 and ISDN PRI Modules
NM-8CE1T1-PRI1-port Channelized E1/T1/ISDN PRI High-Speed WAN Interface Card (HWIC)
Data Sheet
HWIC-2CE1T1-PRI2-port Channelized E1/T1/ISDN PRI HWIC
Data Sheet
HWIC-1CE1T1-PRI1-port Channelized E1/T1/ISDN PRI HWIC
Data Sheet
ISDN BRI Modules
VIC2-2BRI-NT/TE2-port VIC card-BRI (NT and TE)
Data Sheet
HWIC-4B-S/T4-port ISDN BRI High-Speed WAN Interface Card
Data Sheet
HWIC-1B-U1-port ISDN BRI U High-Speed WAN Interface Card
Data Sheet
WIC-1B-S/T-V31-port ISDN WAN Interface Card (dial and leased line)
Data Sheet
EM-4BRI-NT/TE4-port voice/fax expansion module BRI
Data Sheet
ATM Modules
NM-1A-OC3-POM1-port ATM OC-3 module with single pluggable optical module (Small Form-Factor Pluggable) slot
NM-1A-T3/E31-port T3/E3 ATM network Module
Data Sheet
AIM-ATM-4T1/E1T1/E1 ATM bundle includes 2 VWIC2-2MFT-T1/E1s and 1 AIM-ATM
AIM-ATM-1T1/E1T1/E1 ATM bundle includes 1 VWIC2-1MFT-T1/E1 and 1 AIM-ATM
AIM-ATMHigh-performance ATM SAR AIM
AIM-ATM-8AIM supporting ATM features for Cisco MWR 1941 and Cisco 3825-DC routers.
Note: Supported as part of the Mobile Wireless Edge Routers. Requires IOS 12.4(12)MR1.
Sync/Async Modules
HWIC-16A16-port Async HWIC
Data Sheet  Q&A
HWIC-8A8-port Async HWIC
Data Sheet  Q&A
HWIC-8A/S-2328-port Async/Sync Serial HWIC, EIA-232
Data Sheet   Q&A
HWIC-4A/S4-port Async/Sync Serial HWIC
Data Sheet   Q&A
HWIC-2A/S2-Port Async/Sync Serial High-Speed WAN Interface Card
Data Sheet   Q&A
NM-32A32-port Async/Sync Serial network module
Analog Dialup and Remote Access Modules
WIC-2AM-V22-port analog modem WIC
Data Sheet
WIC-1AM-V21-port analog modem WIC
Data Sheet
Digital Modem Module
PVDM2-36DM36-port digital modem module
Data Sheet  Q&A
PVDM2-24DM24-port digital modem module
Data Sheet  Q&A
PVDM2-12DM12-port digital modem module
Data Sheet  Q&A
Circuit Emulation Modules
USB Flash Storage Modules
MEMUSB-256FT256 MB USB Flash
Data Sheet
MEMUSB-128FT128 MB USB Flash
Data Sheet
End of sales (EoS) Modules
The modules below are supported on the 2800 Series Integrated Services Routers per the terms described in their data sheets and End-of-Sale bulletins.
AIM-ATM-1E1High-performance ATM AIM/E1 Bundle, AIM-ATM with VWIC-1MFT-E1
AIM-ATM-1T1High-performance ATM AIM/T1 Bundle, AIM-ATM with VWIC-1MFT-T1
AIM-ATM-4E14E1 ATM IMA Bundle, AIM-ATM with 2 qty VWIC2-2MFT-T1/E1
AIM-ATM-4T14T1 ATM IMA Bundle, AIM-ATM with 2 qty VWIC2-2MFT-T1/E1
AIM-COMPR2-V2Data compression AIM
AIM-COMPR4Data compression AIM
AIM-APPRE-102-K9Application Runtime Engine AIM
AIM-CUECisco Unity Express Voice-Mail AIM
Data Sheet   Q&A   End-of-Sale Notice
AIM-VPN/HPII-PLUSHigh-performance DES/3DES/AES VPN Encryption/Compression Module
AIM-VPN/EPII-PLUSDES/3DES/AES VPN Encryption/Compression AIM Module
EM-HDA-8FXSEight-port FXS voice/fax expansion module
EM-HDA-4FXOFour-port FXO voice/fax expansion module
End-of-Sale Notice
HWIC-AP-AG-A802.11a/b/g HWIC access point interface card
HWIC-AP-AG-J802.11a/b/g HWIC access point interface card
HWIC-3G-GSM3GWWAN HWIC-HSDPA/UMTS/EDGE/GPRS-850/900/1800/1900/2100 MHz
MEMUSB-64FT64 MB USB Flash
NM-16ESW-PWR16-port 10/100 Cisco EtherSwitch Network Module with in-line power support
NM-16ESW-PWR-1GIG16-port 10/100 Cisco EtherSwitch Network Module with in-line power and Gigabit Ethernet
NMD-36-ESW-PWR-2GOne 36-port 10/100 EtherSwitch HDSM + Cisco pre-standard PoE and 2GE
NMD-36-ESW-2GIGOne 36-port 10/100 EtherSwitch HDSM with 2 GE (1000BaseT)
NMD-36-ESWOne 36-port 10/100 EtherSwitch High Density Service Module
NMD-36-ESW-PWROne 36-port 10/100 EtherSwitch HDSM with Cisco pre-standard PoE
NME-XD-24ES-1S-POne 24-port 10/100 Cisco EtherSwitch service module with802.3af, 1 SFP, Cisco StackWise connectors, and IP Base
NME-VMSS-16Cisco Video Management and Storage System NME
NM-2FE2W-V22-port 10/100 Ethernet 2 WAN Card Slot Network Module
NM-1FE2W-V21-port 10/100 Ethernet 2 WAN Card Slot Network Module
NM-1A-T31-port DS-3 ATM network module
NM-1A-E31-port E3 ATM network module
NM-1CE1T1-PRI1-port Channelized E1/T1/ISDN PRI network module
NM-2CE1T1-PRI2-port Channelized E1/T1/ISDN PRI network module
NM-1FE-FX-V21-port 10/100BASE-FX Single Mode Fiber Fast Ethernet Network Module
NM-1GE1-port Cisco Gigabit Ethernet network module
NM-4A/S4-port Async/Sync Serial network module
NM-8A/S8-port Async/Sync Serial network module
NM-16AM-V216-port analog modem network module with v.92
NM-8AM-V28-port analog modem network module with v.92
NM-AIC-64Alarm monitor and control network module
NM-AIR-WLC6-K9Cisco wireless LAN 6 AP controller network module
NME-APA-E3Cisco Application Performance Assurance Network Module
NM-CE-BP-40G-K9Cisco Content Engine Network Module, basic performance, 40-GB IDE hard disk
NM-CE-BP-40G-S-K9Cisco Content Engine Network Module for Security, basic performance, 40-GB IDE hard disk
NM-CE-BP-80G-K9Cisco Content Engine Network Module, basic performance, 80-GB IDE hard disk
NM-CE-BP-80G-S-K9Cisco Content Engine Network Module for Security, basic performance, 80-GB IDE hard disk
NM-CEM-4TE14-port T1/E1 Circuit Emulation module
NM-CEM-4SER4-port serial circuit emulation module
NM-CIDS-K9Cisco IDS Network Module
NM-CUECisco Unity Express Voice-Mail Network Module
End-of-Sale Notice
NM-CUE-ECCisco Unity Express Voice-Mail Network Module extended capacity
End-of-Sale Notice
NM-HDA-4FXSHigh density analog voice/fax network module with 4 FXS
NM-HDVHigh Density Voice/Fax Network Module
NM-HDV-1E1-121-port 12-channel E1 voice and fax network module
NM-HDV-1E1-301-port 30-channel E1 voice and fax network module
NM-HDV-1E1-30E1-port 30-enhanced-channel E1 voice and fax Network Module
NM-HDV-1J1-301-port 30-channel J1 high-density voice network module
NM-HDV-1J1-30E1-port 30-enhanced-channel J1 high-density voice network module
NM-HDV-1T1-121-port 12-channel T1 voice and fax network module
NM-HDV-1T1-241-port 24-channel T1 voice and fax network module
NM-HDV-1T1-24ESingle-port 24 enhanced channel T1 voice and fax network module
NM-HDV-2E1-602-port 60-channel E1 voice and fax network module
NM-HDV-2T1-482-port 48-channel T1 voice and fax network module
NM-HDV-FARM-C3636-port transcoding and conferencing DSP farm
NM-HDV-FARM-C5454-port transcoding and conferencing DSP farm
NM-HDV-FARM-C9090-port transcoding and conferencing DSP farm
NME-AON-K9Cisco 2800/3700/3800 Series AON Enhanced Network Module
NM-NAMCisco 2600, 3660, and 3700 series network analysis module
NME-NAM-80SCisco Branch Routers Series Network Analysis Network Module 80 GB (SATA)
Data Sheet   Q A   More Information   End-of-Sale Notice
NME-TPONetwork Capacity Expansion NME for Cisco 3800 ISRs
AIM-TPO-1Network Capacity Expansion for Cisco 1800/2800/3800 ISRs
AIM-TPO-2Network Capacity Expansion for Cisco 1800/2800/3800 ISRs
NM-8T1-IMA8-port T1 ATM Network Module with IMA
NM-8E1-IMA8-port E1 ATM Network Module with IMA
NM-4T1-IMA4-port T1 ATM Network Module with IMA
NM-4E1-IMA4-port E1 ATM Network Module with IMA
NM-4B-S/T4-port ISDN BRI network module (S/T interface)
NM-4B-U4-port ISDN BRI network module with integrated Network Termination 1 (NT1) (U interface)
NM-8B-U8-port ISDN BRI network module with integrated NT1 (U interface)
NM-8B-S/T8-port ISDN BRI network module (S/T interface)
NM-30DM30 Port Digital Modem Network Module
NM-24DM24 Port Digital Modem Network Module
NM-18DMPort Digital Modem Network Module
NM-12DMPort Digital Modem Network Module
NM-6DM6 Port Digital Modem Network Module
NM-16A16-port Async/Sync Serial network module
NM-16A/S16-port Async/Sync Serial network module
NM-1HSSI1-port High-Speed Serial Interface (HSSI) network module
WIC-1ADSL-DG1-port ADSL over basic telephone service with dying-gasp WIC
WIC-1ADSL-I-DG1-port ADSL over ISDN with dying-gasp WIC
WIC-1AM1-port analog modem WIC
WIC-2AM2-port analog modem WIC
Data Sheet   End-of-Sale Noticehttp://www.cisco.com/en/US/customer/prod/collateral/modules/ps6247/product_data_sheet0900aecd80232473.html
WIC-1B-U-V21-port ISDN BRI NT-1 WIC
WIC-1T1-port high-speed serial WIC
WIC-2T2-port high-speed serial WIC
WIC-1DSU-T1-V21-port T1/Fractional-T1 DSU/CSU WIC
WIC-2A/S2-port Async/Sync Serial WAN Interface Card
WIC-1ADSL1-port asymmetric DSL (ADSL) over POTS service WIC
WIC-1SHDSL1-port G.SHDSL WIC (2-wire only)
WIC-1SHDSL-V21-port G.SHDSL WIC (2-wire or 4-wire)
VIC-1J1Single Port J1 Voice Interface Card
VIC-2DID2-port DID voice and fax interface card
VIC-4FXS/DID4-port FXS or DID VIC
VIC2-2FXS2-port VIC-FXS
VIC2-2E/M2-port VIC-ear and mouth (E&M)
VWIC-1MFT-T11-port RJ-48 multiflex trunk-T1
VWIC-2MFT-T12-port RJ-48 multiflex trunk-T1
VWIC-2MFT-T1-DI2-port RJ-48 multiflex trunk-T1 with drop and insert
VWIC-1MFT-E11-port RJ-48 multiflex trunk-E1
VWIC-2MFT-E12-port RJ-48 multiflex trunk-E1
VWIC-2MFT-E1-DI2-port RJ-48 multiflex trunk-E1 with drop and insert
VWIC-1MFT-G7031-port RJ-48 multiflex trunk-G.703
VWIC-2MFT-G7032-port RJ-48 multiflex trunk-G.703
