How to limit the dialing based on the amount of communication cost by ISDN Router 1812j
prometricjapan
I have 1812j with ISDN line.
Recently Accidentaly the ISDN Router was dialing every 1 minute because of the config was not right.
It was too late to find out.
And I got the expensive bill from the telephone company.
The issue was the configuration.
However I want to know how to protect the same issue for next time.
The idea is I want to stop dialing if the dialing cost is over than appropriate amount.
For example, if dialing cost reach to $200, then stop dialing and alert to the system administator by E-mail or something.
There is the way to limit the timed-out but this won't help for that.
If is there any way to protect from such, please let me know.
I would appreciate for all your help.
Seitaro
paolo bevilacqua
This cannot easily be done in the router directly. It could be done however, with EEM scripting.
Also, you can set alarms in the managent platform, when hopefully you have one.
paolo bevilacqua
Thanks Paolo.
Can I ask what kind of alarm can set on the management tool?
Or what kind of parameter should I check?
Seitaro
Read EEM documentation for an explanation of what it can do.
Please remember to rate useful posts clicking on the stars below.
