how to login from aux of router to console of a switch
sur_babu
Guys,
Donno possible or not, but my Q is if a console cable is attached to a switch and the other end to the aux of a router....how do we login from the router to that switch? is it possible?
Surajit
--Surajit
dhillyard
aaa authentication login login-auth-none none
line aux 0
no vacant-message
login authentication login-auth-none
modem DTR-active
special-character-bits 8
no exec
transport input telnet
escape-character NONE
stopbits 1
Then do a "sho line" to find the line number of your AUX port. You can now telnet to the IP of any interface on your router on port [2000 + line # of AUX] and gain access to the switch.
For example, if a Loopback IP on your router is 10.10.10.10 and the line number of the AUX port is 161, you can execute "telnet 10.10.10.10 2161"
Hope this is what you're looking for...
gpulos
Level 8
Level 8
you would need to setup both AUX as SLIP interfaces. (this requires IP connectivity enabled on the aux ports)
haven't tried it but if both are setup as SLIP, should be able to communicate via IP
see this link for more info:
http://www.cisco.com/en/US/tech/tk801/tk36/technologies_tech_note09186a0080093c76.shtml
additional async/slip commands can be found here:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1828/products_command_reference_chapter09186a00800ca519.html
command to connect?
dhillyard
line aux 0
no vacant-message
modem DTR-active
no exec
stopbits 1
Xactly.......thanks....
