How to make changes to running config on multiple routers
Angelo ANELLO
Hi Guys,
     I would like to know if it is at all possible to make changes to the running-config of multiple routers in one go.  For example, we are in the process of changing the server that is hosting the DHCP service in our network and as a result we need to change the ip-helper address on all routers.
Is there a way or application that we can use to complete this or will it need to be done singularly?
Your help is appreciated
Kind Regards
Angelo
2 Accepted Solutions
Calin C.
Level 5
Level 5
If your devices are configured for SNMP and you have a software (CiscoWorks is an example) you can push the new configuration on all devices at the same time, or do a schedule when the software should do this.
HTH,
Calin
We use Kiwi CatTools from SolarWinds for automating tasks like this.
HTH Paul ****Please rate useful posts****
Calin C.
Level 5
Level 5
HTH,
Calin
