Cisco 7613 Router - Multicasting is not working
Akhileshpk_2
Hi All,
We are facing an issue while configuring Multicasting on Cisco 7613 Router (IOS - c7600rsp72043-advipservicesk9-mz.122-33.SRE2.bin).
Below explains the connectivity details of the same:
     PC (Multicast Server) --> Cisco 7613 Router--> PC (Multicast Client)
     Multicast Server - 20.1.1.2 - Connected to 12/1 port of the 7613 Router (Gig12/1 - 20.1.1.1)
     Multicast Client  - 30.1.1.2 - Connected to 12/2 port of the 7613 Router (Gig 12/2 - 30.1.1.1)
     Multicast IP Address  - 239.10.10.10
The configuration of the 7613 Router is shown below (Attached also):
          ip multicast-routing
          interface GigabitEthernet12/1
           ip address 20.1.1.1 255.255.255.0
           ip pim sparse-dense-mode
           ip igmp join-group 239.10.10.10
           speed 100
           no cdp enable
          end
          interface GigabitEthernet12/2
           ip address 30.1.1.1 255.255.255.0
           speed 100
           no cdp enable
          end
Issue is show ip mroute does not show the incoming interface; instead it shows as NULL and the client is not receiving the multicasted video. (Attachede the show ip mroute result)
Tried the Following:
     Configured the interfaces in the Dense mode,
     Configured same router as the RP
     Both the Client and the Server are pinging eachother and can ping to 239.10.10.10 also.
     While connecting the Multicast Source and the Client back to back,cit is wokring fine. (We are using VLC 0.9.9 as the multicast Source and client)
     Changed the Router ports and tried.
Please help to solve the issue.
Thanks in Advance !!!
Akhilesh P K
6 Replies 6
Marwan ALshawi
your server supposed to send Mcast traffic on the group 239.10.10.10 and the client suuposed to join this group
not sure how ( software maybe )
but in anyway yo have to remove the bellow command from all the interfaces of your router
this is just for testing you can let the interface to join a gorup
alos try if supported
ip multicast routing distributed
igmp snooping
Jon Marshall
Just a quick check.
VLC by default sets to the TTL to 1 for the multicast stream. This means it won't work across L3 boundaries ie. it will only work in the same vlan.
Can you check the TTL setting on VLC when you setup the stream and if it is 1 then increase it to 2 in your case as it only needs to go across one L3 hop.
*** Edit - Marwan is correct when he says if you are testing with VLC you do need the "ip igmp join-group ..." interface comands.
Jon
Thanks for your quick response...!!!
1. Enabled IGMP Snooping and tried - Same Result
2. IGMP-Group 239.10.10.10 command removed and tried  - Same Result
3. VLC TTL made as more than 1 (2, 3 and 4) - Same Result
Akhilesh P K
please after you did this updates do clear ip mroute *
then capture debug ip mpack
then try your multicast and post the debug here
Hi all,
After degrading the VLC version from 0.9.9 to 0.8.6, it is worknig fine !!!
Thanks for the support !!!
Akhil
thanks for the update
and dont forget to rate the helpful posts
