How to make spoke going to hub to get to the Internet
news2010a
Level 3
Level 3
Imagine MPLS network. Total of 4 sites.
HQ-HUB is the only site with access to the Internet.
So if Site1 or Site2 or Site3 need to access the Internet, traffic will have to go through HQ-HUB and from there reach the Internet.
Question:
I have routes 2851's on the spoke sites.
Which command or mechanism you would explore in this case to make the spoke sites point to the HQ-HUB to reach the Internet?
Would you do this based on DNS settings or getting an access-list & static route defining when the spoke routers traffic need to go the internet, point to the HUB-HQ as the default?
Edison Ortiz
Inject a default route from the Hub site towards the MPLS Cloud.
All spokes will follow the default and once it reaches the Hub site, traffic should follow the internet.
Mahesh Gohil
Level 7
Level 7
Just an addition.
It is required to know what protocol you are running with MPLS provider.
If it is static the step is below
> On spoke you need to have static default pointing to wan ip configured at provider end for spoke site
> On MPLS provider site need to have default route pointing toward HUB wan IP and redistribute it in address-family
   (To be configured at HUB site) (You need to speak to provider for default route)
If you are running dynamic protocol
> You need to push default from HUB site and provider will pass same default to spoke site.
I request you to discuss the same with provider if you are running static protocol
Mahesh
milan.kulik
Level 10
Level 10
IMHO, the safest way how users should reach the Internet is using a proxy in the HQ.
You don't need to change your routing at all then, the users just need to know the proxy server IP to reach.
BR,
Milan
